I am trying to join a WebEx meeting from Ubuntu 12.04. I can join but I do not see the live chat messages, I hear no sound, and I cannot see the presentation. I have tried using Ubuntu 12.04 64-bit and 32-bit. The one time I was able to get it working, it was on 32-bit and the sound worked for a few minutes, but then stopped; I could see the presentation, but I could not see the chat messages. I have installed Oracle Java 7 from the webupd8 PPA and downloaded all Ubuntu updates as of today May 28th, 2013.
The WebEx system requirements page says they require Ubuntu 10.x or 11.x 32-bit. Does this mean in May of 2013 they do not support Ubuntu 12.04?!?
UPDATE May 29th: It seems I was looking at the old system requirements. It looks like these are the current WebEx system requirements. So, it says: "WebEx will support any Linux distribution as long as it meets the following minimum requirements:
- Kernel: 2.6 or later
- X Lib: X11R6 or later compatible
- C++ Lib: libstdc++ 6
- Desktop Environment, XFce 4.0 or later, KDE, Ximian, Gnome
- GDK/GTK. version: 2.0 or later
- Glib: 2.0 or later
- Sun Java 1.5 or later"
I am stilling learning about Ubuntu and Linux, but I know that Ubuntu 12.04 comes with a newer kernel (3.2), uses the X11 window manager, Unity is based on Gnome, and I installed Oracle Java 7. When I search the software center for these other packages I am a bit confused since there are so many options. I am guessing that my problem is not having one or more of these packages and/or incompatible versions. Does anyone have any insight on this?
UPDATE May 30th 10am EST. I tried installing ia32-libs as recommended here; same problem. I enabled the java console; here is the output:
Java Plug-in 10.21.2.11
Using JRE version 1.7.0_21-b11 Java HotSpot(TM) 64-Bit Server VM
User home directory = /home/mrmccormack
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to
JDownload version 2009.03.03
Java version: 1.7.0_21
Java home: /usr/lib/jvm/java-7-oracle/jre
OS name: Linux
OS arch: amd64
OS version: 3.2.0-44-generic
[JDownload] Java Client Service home:https://join-test.webex.com/client/T27L10NSP25EP3/javaclient/webex/
[JDownload] Production home: /home/mrmccormack/.webex/1124
[MySystem version 2009.02.05.01]InitSystem ...
###1 Runtime total memory: 78249984, free memory: 54440552
###2 Runtime total memory: 78249984, free memory: 68586336
###### try to load class DBR in MyCloassLoader2...
Loading native DBR...
java.lang.UnsatisfiedLinkError: /home/mrmccormack/.webex/1124/libdbr.so: /home/mrmccormack/.webex/1124/libdbr.so: wrong ELF class: ELFCLASS32 (Possible cause: architecture word width mismatch)
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary1(ClassLoader.java:1939)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1864)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1838)
at java.lang.Runtime.loadLibrary0(Runtime.java:845)
at java.lang.System.loadLibrary(System.java:1084)
at DBR.loadNativeDBR(DBR.java:22)
at DBR.(DBR.java:93)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:525)
at java.lang.Class.newInstance0(Class.java:374)
at java.lang.Class.newInstance(Class.java:327)
at DB.reset(DB.java:192)
at MySystem.InitSystem(MySystem.java:132)
at JDownload.run(JDownload.java:253)
at java.lang.Thread.run(Thread.java:722)
XXX[DBR]load native library failed
###1 Runtime total memory: 78249984, free memory: 67003992
###2 Runtime total memory: 78249984, free memory: 68922760
###1 Runtime total memory: 78249984, free memory: 66904832
###2 Runtime total memory: 78249984, free memory: 68924592
Begin of log initialization
initFileOutputStream() run ...
End of log initialization
Begin of WBXTracePallet initialization
End of WBXTracePallet initialization
Resource: svc
Resource: svc_en
Resource: svc_en_US
[SvcUI].................. SvcUI construct begin .................. 2010-05-02
[SvcUI].................. SvcUI construct end ..................
[SvcUI][init] type:0 IService:SvcUIService@326238b5 SVC component version 2010.07.27
###### try to load class JNRW in MyCloassLoader2...
java.lang.UnsatisfiedLinkError: /home/mrmccormack/.webex/1124/libatdv.so: /home/mrmccormack/.webex/1124/libatdv.so: wrong ELF class: ELFCLASS32 (Possible cause: architecture word width mismatch)
at JNRW.(JNRW.java:45)
at jDocView.CreateDocViewUI(jDocView.java:629)
at jDocView.PDNewInstance(jDocView.java:4293)
at MeetingClientFrame.(MeetingClientFrame.java:289)
at jmeetingclient.constructMainFrame(jmeetingclient.java:325)
at ConfMgr.connectToMeeting(ConfMgr.java:197)
at jmeetingclient.init(jmeetingclient.java:275)
at JDownload.run(JDownload.java:278)
XXX[JNRW]load native library failed
###1 Runtime total memory: 78249984, free memory: 44387408
###2 Runtime total memory: 78249984, free memory: 64752880
###1 Runtime total memory: 78249984, free memory: 64549200
###2 Runtime total memory: 78249984, free memory: 66873512
[SvcUI][onMessageFromService] SET_ROSTER_CHANGED:220 change:1 SvcUI:743824904
[SvcUI][setRosterChanged] index:-1 change:1 userID:16781313 attendeeID:3 userID:16781313 userName:Kevin U12 Desktop isHost:false isPresenter:false
chat component version = 2010.05.18.1040
Resource: atlchat
Resource: atlchat_en
Resource: atlchat_en_US
notes component version = 2010.04.27.0001
Resource: atnotes
Resource: atnotes_en
Resource: atnotes_en_US
Exception in thread "AWT-EventQueue-3" java.lang.IllegalStateException: This function should be called while holding treeLock
at java.awt.Component.checkTreeLock(Component.java:1196)
at java.awt.Container.validateTree(Container.java:1682)
at WbxComboBox.matchItemFont(WbxComboBox.java:188)
at WbxComboBox.setSelectedItem(WbxComboBox.java:170)
at ChatUI.setNonListItem(ChatUI.java:1142)
at ChatUI.updateSendToItems(ChatUI.java:1099)
at ChatUI.updateSendTo(ChatUI.java:895)
at simpleChat$1.run(simpleChat.java:310)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:727)
at java.awt.EventQueue.access$200(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:688)
at java.awt.EventQueue$3.run(EventQueue.java:686)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:697)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
at ChatControlPane.access$100(ChatControlPane.java:61)
at ChatControlPane$1$1.run(ChatControlPane.java:120)
