By default when I open an image it fits to the window size (scaled down). I have to hit the button Show the image at its normal size every time when I go to the Next/Previous image or open a new image.
I tried View images fit to width in Image Viewer, but it doesn't work.
Zanna
  • 72,312
Tosho
  • 548
I think that it is probably just impossible. Image Viewer is a pretty simple app generally.
What I would recommend is installing Gthumb, which has more functions, including the one you need.
sudo apt-get install gthumb
There you can find this option in Preferences > Viewer tab I guess.
I know that this isn't the exact answer you're looking for, but I hope that it will help anyway.
Zanna
  • 72,312
kcpr
  • 1,472
The only suggestion I can come up with is the qiv image viewer
I hope this helps
Simon
  • 4,843
This just needs the maintainer of Eye of GNOME (eog) to create a plugins file for version 3.6.2.
There is one for 3.6.1, and copying it (with only a minor change) should solve this. Within the download file (.zip or .tar.gz) the file '/eog-plugins/config.ac' needs line 5 changed: from [3.6.1] to [3.6.2]. The remaining code seems to all be >= 3.5.5 compatible.
This should be raised as a bug/feature ..
david6
  • 14,528
  • 38
  • 46
