I use Ubuntu 12.04. Recently I have installed XAMPP 1.8.1 in my system. I set password to: XAMPP pages, MySQL/phpMyAdmin, MySQL root and FTP.
But after that when I try to login to phpMyAdmin page with username 'root' and my assigned password, it doesn't login and shows a page like:
Also when I click on 'CD Collection' item from the left panel of my XAMPP page it shows:
Warning: mysql_connect(): Access denied for user 'root'@'localhost' (using password: NO) in /opt/lampp/htdocs/xampp/cds.php on line 64
Could not connect to database!
Is MySQL running or did you change the password?
Oh! another thing, I edited the /opt/lampp/etc/extra/httpd-xampp.conf file to:
<Directory "/opt/lampp/phpmyadmin">
AllowOverride AuthConfig Limit
Require all granted
</Directory>
but no success...
I am complete newbie to php, mySQL, FTP and this XAMPP. Could anyone please tell me how can I login to my phpMyAdmin page??? did I do anything wrong???
Mitch
  • 109,787
rim
A confusing point for almost everyone who starts using mysql is that 'root' and 'root@localhost' are two different roles and as such could (and some would argue that they actually should) have different passwords. It is quite possible you are trying to log-in as user 'root@localhost' and you are providing the password for 'root' role.
If this is the case, you can remedy it quite easily. Log-in to the database server using the CLI tool mysql as user root like this:
mysql --user=root --password
The tool will ask for your root password (not system root but database root). Now you can modify the password of 'root'@'localhost' like this:
UPDATE mysql.user SET Password=PASSWORD('cleartext password')
  WHERE User='root' AND Host='localhost';
FLUSH PRIVILEGES;
Now try to log-in through phpMyAdmin using the newly set password.
hmayag
  • 2,266
  • 22
  • 24
Check the following articles:
https://help.ubuntu.com/community/MysqlPasswordReset
How to change root password for mysql and phpmyadmin
Ahmadgeo
  • 1,421
I have, after 3 days of searching, got my phpMyAdmin working.
Step 1
Purge the old phpMyAdmin from the system with:
sudo apt-get purge phpmyadmin
You are offered the option of saving any info or deleting the whole lot.
Step 2
Download and install the whole caboodle again with
sudo apt-get install phpmyadmin
As you install you are asked for the Admin password (This is the password which you log in with)
Next you are asked for a password to access the phpMyAdmin UI.
Enter a new password here (I'll pretend that this is a123z ) Then confirm your password by entering it in the next box.
The script will end soon after
Step 3
Logging in to phpMyAdmin
The phpMyAdmin can be found at http://localhost/phpmyadmin/
Your username is: root
Your password is: a123z
(Not your log in password!) That's it, you are in and running.
Simon
  • 4,843
