48
I've set up mysql and phpmyadmin and chose not to set a password when installing hoping that once set up i could login with root and no password but i get the following error from phpmyadmin:
Login without a password is forbidden by configuration (see AllowNoPassword)
I have previously moved the phpmyadmin folder to /var/www/
I have tried changing the following line
$cfg['Servers'][$i]['AllowNoPassword'] = false;
to
$cfg['Servers'][$i]['AllowNoPassword'] = true;
but still had no success, so i am wondering is there a way i can change the root passwords for both so i can access phpmyadmin and create databases.
Rinzwind
  • 309,379
Jon
  • 585
You can change the mysql root password by logging in to the database directly (mysql -h your_host -u root) then run
SET PASSWORD FOR root@localhost = PASSWORD('yourpassword');
phpmyadmin should use that password so not quite sure what you mean by "for both".
Make sure to set the new password into phpmyadmin's config.inc.php too, at line
$cfg['Servers'][$i]['password'] = 'yourpassword';
Otherwise, phpmyadmin may not work, echoing
Access denied for user 'user'@'localhost' (using password: YES)
geermc4
  • 1,503
30
It depends on your configuration. Follow the instruction below to reconfigure phpmyadmin, and reset MySQL password.
  1. Ctrl + Alt + T to launch terminal
  2. sudo dpkg-reconfigure phpmyadmin
  3. Connection method for MySQL database for phpmyadmin: unix socket
  4. Name of the database's administrative user: root
  5. Password of the database's administrative user: mysqlsamplepassword
  6. MySQL username for phpmyadmin: root
  7. MySQL database name for phpmyadmin: phpmyadmin
  8. Web server to reconfigure automatically: apache2
  9. ERROR 1045
  10. ignore
  11. sudo dpkg-reconfigure mysql-server-5.5
  12. New password for the MySQL "root" user: mysqlsamplepassword
  13. Repeat password for the MySQL "root" user: mysqlsamplepassword
  14. After all this run following command on terminal to secure your mysql server. sudo mysql_secure_installation
  15. Enter current password for root (enter for none): mysqlsamplepassword
  16. Change the root password? [Y/n] n
  17. Remove anonymous users? [Y/n] y
  18. Disallow root login remotely? [Y/n] y
  19. Remove test database and access to it? [Y/n] y
  20. Reload privilege tables now? [Y/n] y
Wish it helps!
Have a nice day!
Anwar
  • 77,855
13
I recently came across this very same issue Ubuntu 12.04. I just couldn't seem to login with root & no password. I set the AllowNoPassword setting to TRUE in the config. Later I found out that I was editing the wrong config.inc.php file to add the AllowNoPassword setting.
Edit:
/etc/phpmyadmin/config.inc.php
Not:
/usr/share/phpmyadmin/config.inc.php
I believe the first is the debian local config file, which will override the usr version.
jjwdesign
  • 320
