I'm using Dell Inspiron N4030 laptop. I'm using Ubuntu 13.04 64 bit.
Bluetooth adapter is not found. How to active that?
rfkill list
1: phy1: Wireless LAN
    Soft blocked: no
    Hard blocked: no
2: brcmwl-0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
Zanna
  • 72,312
gobinkl
  • 19
Make sure that the hardware switch is on.
To activate your Bluetooth, you will need to hold down the FN key, and then tap the F2 key once. This should activate the Bluetooth.
Also, Press the F2 key when you power on the system. This should take you to the Bios Screen. Under the Advanced Tab select wireless, and make sure that the bluetooth is set to enabled.
Mitch
  • 109,787
