I have to two operating systems in my computer, Ubuntu and XP. When I try to boot up Ubuntu, I get the following message:
mount:mounting/dev on/root/dev failed:No such file or directory
mount:mounting/sys on/root/sys failed:No such file or directory
mount:mounting/proc on/root/proc failed:No such file or directory
target file system doesn't have/sbin/init noinit found.try passing init=bootarg.
busy boxv1.13.3(ubuntu 1.1.13.3-1ubuntu11)built-in shell(ash)enter'help'for alist of built-in commands.
(initramfs)
What can I do to boot up Ubuntu?
Mitch
  • 109,787
kerala
Boot from the Ubuntu Live CD and open Terminal.
Run this command: sudo fdisk -l (to get the device name):
radu@Radu: ~ > sudo fdisk -l
[sudo] password for radu:
Disk /dev/sda: 250.1 GB, 250059350016 bytes
255 heads, 63 sectors/track, 30401 cylinders, total 488397168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x004aa9ec
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *        2048      718847      358400    7  HPFS/NTFS/exFAT
/dev/sda2          718848    61431807    30356480    7  HPFS/NTFS/exFAT
/dev/sda3        61432621   463410989   200989184+   f  W95 Ext'd (LBA)
/dev/sda4       463410990   488392064    12490537+  83  Linux
/dev/sda5        61432623   450826239   194696808+   7  HPFS/NTFS/exFAT
/dev/sda6       450828288   463409151     6290432   82  Linux swap / Solaris
In my case, my Ubuntu is on: /dev/sda4.
Run sudo fsck /dev/sda4 (you should change /dev/sda4 with your device where is installed Ubuntu). Restart the system and boot normally.
Sources: How to Fix an Ubuntu Error: "No init found. Try passing init= bootarg".
Another related answers you can find here: How can I repair grub? (How to get Ubuntu back after installing Windows?).
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
