I have Windows 7, and I'm trying to dual boot Windows 7 and Ubuntu. However, when I try to install Ubuntu with a USB, it doesn't give me the option to dual boot. I can only "Replace Windows 7 with Ubuntu", or "Something Else".
I've installed Ubuntu on this computer before, and this option was present. What I'm asking for is a way to get that option, or how to use the "Something else" option.
Jason
How many partitions do you have. If you happen to have 4 primary partitions, then Ubuntu will say to replace your existing Windows since there are no more primary partition slots left (The maximum is 4 primary partitions).
Check to see if this is the case and decide which partition you wish to remove or change to a logical partition.
The explanation (With images) can be found in Is it possible to have Windows 8 and Ubuntu on the same hard drive?
The answer should give you an idea of how to remove one of the primary ones and create a logical one which can be extended to several partitions.
Luis Alvarado
  • 216,643
