I've just installed Ubuntu 13.04 on my MacBook Air, after toying around for awhile the machine felt really slow, so I checked out the CPU frequency. cpufreq-info, it reports 800MHz on all 4 cores (which is the lowest setting). The governor is set to ondemand. Now when I put some load on the system (running a small script that hashes stuff four times) the machine grinds to a hold, but cpufreq-info is still reporting 800MHz. I can manually set the frequency to 2GHz, which solves the performance problem, but will cost me my battery.
This is the output of cpufreq-info:
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
driver: acpi-cpufreq
CPUs which run at the same hardware frequency: 0 1 2 3
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: 10.0 us.
hardware limits: 800 MHz - 2.00 GHz
available frequency steps: 2.00 GHz, 2.00 GHz, 1.90 GHz, 1.80 GHz, 1.70 GHz, 1.60 GHz, 1.50 GHz, 1.40 GHz, 1.30 GHz, 1.20 GHz, 1.10 GHz, 1000 MHz, 900 MHz, 800 MHz
available cpufreq governors: conservative, ondemand, userspace, powersave, performance
current policy: frequency should be within 800 MHz and 2.00 GHz.
The governor "ondemand" may decide which speed to use
within this range.
current CPU frequency is 800 MHz (asserted by call to hardware).
cpufreq stats: 2.00 GHz:5,75%, 2.00 GHz:0,47%, 1.90 GHz:0,00%, 1.80 GHz:0,01%, 1.70 GHz:0,01%, 1.60 GHz:0,01%, 1.50 GHz:0,01%, 1.40 GHz:0,01%, 1.30 GHz:0,01%, 1.20 GHz:0,02%, 1.10 GHz:0,01%, 1000 MHz:0,02%, 900 MHz:0,02%, 800 MHz:93,67% (1388)
analyzing CPU 1:
CPUs which need to have their frequency coordinated by software: 1
within this range.
cpufreq stats: 2.00 GHz:3,17%, 2.00 GHz:0,01%, 1.90 GHz:0,01%, 1.80 GHz:0,00%, 1.70 GHz:0,00%, 1.60 GHz:0,01%, 1.50 GHz:0,01%, 1.40 GHz:0,01%, 1.30 GHz:0,01%, 1.20 GHz:0,01%, 1.10 GHz:0,01%, 1000 MHz:0,02%, 900 MHz:0,02%, 800 MHz:96,71% (1433)
analyzing CPU 2:
CPUs which need to have their frequency coordinated by software: 2
within this range.
cpufreq stats: 2.00 GHz:2,69%, 2.00 GHz:0,00%, 1.90 GHz:0,01%, 1.80 GHz:0,01%, 1.70 GHz:0,01%, 1.60 GHz:0,02%, 1.50 GHz:0,01%, 1.40 GHz:0,01%, 1.30 GHz:0,02%, 1.20 GHz:0,02%, 1.10 GHz:0,01%, 1000 MHz:0,02%, 900 MHz:0,02%, 800 MHz:97,16% (1194)
analyzing CPU 3:
CPUs which need to have their frequency coordinated by software: 3
within this range.
cpufreq stats: 2.00 GHz:3,07%, 2.00 GHz:0,02%, 1.90 GHz:0,01%, 1.80 GHz:0,00%, 1.70 GHz:0,01%, 1.60 GHz:0,01%, 1.50 GHz:0,01%, 1.40 GHz:0,01%, 1.30 GHz:0,01%, 1.20 GHz:0,01%, 1.10 GHz:0,03%, 1000 MHz:0,03%, 900 MHz:0,01%, 800 MHz:96,77% (1004)
