I am running Ubuntu 12.04 which comes with poedit 1.4.6. Is there any way to install poedit 1.5+ without compiling it from source?
update: I'd rather not upgrade to 13.04, if at all possible
periklis
  • 165
I use ubuntu 13.04, and I see poedit 1.5 can be installed simply by
$ sudo apt-get install poedit
ruuning this command
$ sudo apt-cache show poedit | grep "Version"
gives me the following result
Version: 1.5.4-1
Suggestion should be simply install by source, or upgrade.
shivshnkr
  • 5,113
There is a backport (PPA) for poedit available for Precise (12.04) available from https://launchpad.net/~schaumkeks/+archive/ppa/+sourcepub/2991913/+listing-archive-extra
You can download the .deb file here:
https://launchpad.net/~schaumkeks/+archive/ppa/+files/poedit_1.5.4-1~ubuntu12.04.1~ppa1_i386.deb
If you are looking for the 64-bit version, you can download it here:
https://launchpad.net/~schaumkeks/+archive/ppa/+files/poedit_1.5.4-1~ubuntu12.04.1~ppa1_amd64.deb
From a terminal (Ctrl-Alt-t), navigate to your download folder and issue the command sudo dpkg -i poedit-dbg_1.5.4-1~ubuntu12.04.1~ppa1_i386.deb
or, to install the 64-bit version, run the following command: sudo dpkg -i poedit_1.5.4-1~ubuntu12.04.1~ppa1_amd64.deb
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
I know the question is a bit old, but I tried what @Kevin Bowen suggests and couldn't find the files.
I added this PPA https://launchpad.net/~schaumkeks/+archive/ppa, updated apt sources but still the installed version is ~1.4.
I downloaded the binary packages from packages in https://launchpad.net/ubuntu/+source/poedit (poedit-dbg_1.5.4-1_i386.deb and poedit_1.5.4-1_i386.deb, BUT, poedit dependes on libdb5.1++, which in my case wasn't installed. Just installed it from the repos and then installed poedit_1.5.4-1_i386.deb and poedit-dbg_1.5.4-1_i386.deb, in that order.
So, it isn't very hard, open your command line and:
wget https://launchpad.net/ubuntu/+archive/primary/+files/poedit-dbg_1.5.4-1_i386.deb
wget https://launchpad.net/ubuntu/+archive/primary/+files/poedit_1.5.4-1_i386.deb
sudo apt-get install libdb5.1++
sudo dpkg -i poedit_1.5.4-1_i386.deb
sudo dpkg -i poedit-dbg_1.5.4-1_i386.deb
The main reason I had to do this is because version < 1.4 uses the X-Lanauge header instead of the Language header, which uses the gettext binary compile .po files.
Hope that helps.
