10
I need to type sudo modprobe snd-hda-intel in order to get my sound card to work.
What config file do I need to edit and what edit should I be looking to make so I can get the sound driver loading at start up so I don't have to type this every time?
Jorge Castro
  • 73,717
Add snd-hda-intel to the end of the file /etc/modules. This will make the snd-hda-intel module load up automatically at boot time.
You can use: sudo sh -c 'echo "snd-hda-intel" >> /etc/modules' to do this.
Alaa Ali
  • 32,213
In /etc/modules you can put every module (one per line) for those you need to load at boot time.
Running this command will append the module to the file:
echo "snd-hda-intel" | sudo tee -a /etc/modules
gertvdijk
  • 69,427
After attempting an "oss4" audio install, I lost audio, and reverting my mistake, did not recover the audio.
Needed to "manually": modprobe snd-hda-intel every boot....
Until I found that the driver had been put in a blacklist.... on the oss4 attempt.
grep snd-hda-intel /etc/modprobe.d/*
/etc/modprobe.d/oss4-base_noALSA.conf:blacklist snd-hda-intel
moved the "oss4-base_noALSA.conf" away from the "/etc/modprobe.d"
sudo mv /etc/modprobe.d/oss4-base_noALSA.conf /root
and now, do not need to manually "modprobe snd-hda-intel" to get audio after every boot....
Hope it helps...
Pilot6
  • 92,041
nicolas_dh
  • 51
