I can't install 12.04.2 from CD because the video is corrupt. I have an S3 pro Savage4 video card and a LCD display. After booting, the top half of the screen sort of appears but is really unreadable. Moving the cursor around sort of helps, but not well enough to make it readable.
Since I'm trying to install from a CD, there is no way to modify anything on it. (The advice given to fix a running system can't be used.) I have 11.10 currently installed but the last time I tried to upgrade it the network adapter driver didn't work, so I had to revert back to 11.10. I don't want to just try the upgrade again because I want to make sure all the drivers are working first.
Is there another 12.04 installation image planned? Is there a way to get past this problem using a CD install?
FNE
  • 103
Try selecting nomodeset and/or acpi=off in the CD boot menu. See this guide: My computer boots to a black screen, what options do I have to fix it?
UPDATE: There are a couple of more options you can try: xmodule=savage xmodule=vesa xmodule=svga norandr nodrm nocomposite no3d noddc
Add them to the kernel command line manually in various combinations, plain vga should work if the card isn't faulty.
grimpitch
  • 809
