20
On 12.04, running as a guest in VirtualBox using two adapters, I was getting this error in response to ifup eth1
RTNETLINK answers: File exists
Failed to bring up eth1
This was the contents of /etc/network/interfaces
# The loopback network interface
auto lo
iface lo inet loopback
# Host-only interface
auto eth1
iface eth1 inet static
        address         192.168.56.20
        netmask         255.255.255.0
        network         192.168.56.0
        broadcast       192.168.56.255
        gateway         192.168.56.1
# NAT interface
auto eth2
iface eth2 inet dhcp
See this question for more about why I configured it this way.
In VirtualBox, how do I set up host-only virtual machines that can access the Internet?
Christian Long
  • 3,217
  • 20
  • 16
The problem was that two default gateways were being set, one static and one by dhcp. You can't have two default gateways with the same metric.
https://bugs.launchpad.net/ubuntu/+source/ifupdown/+bug/1043244/comments/8
The solution: remove the gateway line from the configuration of eth1.
Or, add an explicit metric 100 line to eth1, to give the eth1 gateway a lower priority than the eth2 gateway.
Christian Long
  • 3,217
  • 20
  • 16
