104
In setting up virtual machines with VirtualBox, I often want the following characteristics
  • VM has a static IP
  • host can access VM without port forwarding
  • VM can access the internet
  • I can move my laptop from network to network (e.g. from home to office to coffee shop) without worrying about securing or reconfiguring the VM
None of the VirtualBox network connection methods satisfies these requirements on their own.
  • NAT
    Requires port forwarding if you want to connect to the VM from the host.
  • Host-only
    The VM can not access the internet unless the host is a router.
  • Bridged
    Exposes the VM to the network; not portable.
Christian Long
  • 3,217
  • 20
  • 16
7 Answers7
117
I can get the setup I want by setting up two adapters on the vm.
VirtualBox 4.2.12
Ubuntu 12.04 guest
In VirtualBox > Preferences > Network, set up a host-only network.
Mine is called vboxnet0, it is manually configured:
ip 192.168.56.1
netmask 255.255.255.0
no dhcp
VirtualBox network configuration VirtualBox network configuration
Then, in the network settings for the virtual machine, set up two adapters:
Adapter 1
host only, vboxnet0
Adapter2
NAT
Boot the virtual machine and log in through the console VirtualBox provides.
Run this to see your adapters:
ls /sys/class/net
In my case the adapters were named eth1 and eth2 (and lo, the loopback interface).
Then, edit your network configuration.
sudoedit /etc/network/interfaces
# The loopback network interface
auto lo
iface lo inet loopback
# Host-only interface
auto eth1
iface eth1 inet static
        address         192.168.56.20
        network         192.168.56.0
        broadcast       192.168.56.255
# NAT interface
auto eth2
iface eth2 inet dhcp
Note that eth1 has no default gateway specified. eth2 will get a default gateway from dhcp.
Update March 2018
See this answer from @Hugo14453 for an updated version that works with Ubuntu 17.10 and newer.
Christian Long
  • 3,217
  • 20
  • 16
20
Network configuration has changed in Ubuntu 17.10.1. You now use the netplan config.
I followed this guide here
As a migration of Christian's answer, do the following:
Create a new config file inside of /etc/netplan to hold your host-only adapter config.
e.g sudo nano /etc/netplan/02-netcfg.yaml
Enter the following to configure a static IP of 192.168.56.12 where enp0s3 is the name of your host-only adapter.
network:
    version: 2
    renderer: networkd
    ethernets:
        enp0s3:
            addresses:
                - 192.168.56.12/24
            dhcp4: no
Then run the following two commands:
sudo netplan generate
sudo netplan apply
NAT should work without configuration, run ifconfig to see the result:
enp0s3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.56.12  netmask 255.255.255.0  broadcast 192.168.56.255
        inet6 fe80::a00:27ff:fe06:6cdd  prefixlen 64  scopeid 0x20<link>
        ether 08:00:27:06:6c:dd  txqueuelen 1000  (Ethernet)
        RX packets 252  bytes 23076 (23.0 KB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 208  bytes 30015 (30.0 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
enp0s8: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.0.3.15  netmask 255.255.255.0  broadcast 10.0.3.255
        inet6 fe80::a00:27ff:fe4d:a6b8  prefixlen 64  scopeid 0x20<link>
        ether 08:00:27:4d:a6:b8  txqueuelen 1000  (Ethernet)
        RX packets 95  bytes 94894 (94.8 KB)
        TX packets 85  bytes 7436 (7.4 KB)
Baa
  • 3,750
17
I could solve my problem with a mix of Christian Long solution. I added 2 adapters:
Adapter 1 - NAT
Adapter 2 - host only, vboxnet0
The only diference was in VM's interfaces file:
auto lo
# NAT
auto eth0
iface eth0 inet dhcp
# Host only
auto eth1
iface eth1 inet dhcp
In VirtualBox Network config I left DHCP checked.
After a VM reboot everything worked fine.
Alan Camillo
  • 171
There is another simple way that we don't need to create a new NAT adapter
  1. On the host machine, please add the following iptables rules. This will forward packets through the host and on to the Internet:
    sudo iptables -A FORWARD -o eth0 -i vboxnet0 -s 192.168.56.0/24 -m conntrack --ctstate NEW -j ACCEPT
    sudo iptables -A FORWARD -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT
    sudo iptables -A POSTROUTING -t nat -j MASQUERADE
  2. You will also need to enable IP forwarding on the host by issuing the following command:
    sudo sysctl -w net.ipv4.ip_forward=1
Danatela
  • 13,384
Long Bui
  • 161
I Just added 2 adapters:
Adapter 1 host only, vboxnet0
Adapter2 NAT
And it works perfect, I can access the virtual machine from the host, and I have internet on the vm.
Yeah I had this problem it was a total pain! But I solved it by simply installing Squid Cache Proxy server on my physical PC, and that way - my host-only internet virtualbox PCs could connect to the internet !
I did a quick 3 minute guide for anyone who wants to know how it works.
Zanna
  • 72,312
In my case, I could not see the IP 192.168.250.1 on vboxnet0 (e.g. with "ip addr"), despite setting this in the host-only network settings in VirtualBox, until I created the file /etc/netplan/02-vbox.yaml containing
network:
    version: 2
    renderer: networkd
    ethernets:
        vboxnet0:
            addresses:
                - 192.168.250.1/24
            dhcp4: no
and ran "netplan generate && netplan apply"
