I cannot add any applet to any (top or bottom) panel, cannot delete any panel nor create a new panel. When I right-click on the panel the only options available are: Properties, Help or About panels.
[I cannot post an image because of spam prevention, so I'll do my best]
I can see when I right-click (bold means clickable):
  • Add to panel
  • Properties
  • Delete this panel
  • New panel
  • Help
  • About Panels
Trying to solve this I did what is usually suggested:
gconftool-2 –-recursive-unset /apps/panel # might be optional
rm -rf ~/.gconf/apps/panel
pkill gnome-panel
but I only got a nice empty panel (no Applications Places System, no clock, no shutdown button...) to which I couldn't add any applet, so I decided to take the default profiles in .gconf and .gconfd from a live CD and overwrite mines. Now we are back to the beginning.
I also have tried to lock completely the panel (with both gconf-editor and pessulus) and later unlock it completely but it didn't work.
Here is the system information:
$ lsb_release
Distributor ID: Ubuntu
Description: Ubuntu 10.04.2 LTS
Release: 10.04
Codename: lucid
Thank you very much.
david
  • 91
Reset Gnome.
First of all, backup your settings.
mkdir ~/backup_gnome
mkdir ~/backup_gnome/.gnome/
cp -R ~/.gnome/* ~/backup_gnome/.gnome/
Do this with these folders: .gnome, .gnome2, .gconf, .gconfd, .metacity
Another way is to backup ALL of your settings:
mkdir ~/backup_settings
cp -R ~/.* ~/backup_settings/
After making backups, you can delete all gnome settings:
rm -rf .gnome .gnome2 .gconf .gconfd .metacity
WARNING: If you remove all these folders, you essentially remove all the settings.
After resetting gnome, Logout and Login again (or restart your computer). You panels should be restored, now you can edit them again.
I hope this helped you, but try all the answers before mine, because resetting gnome is like reinstalling gnome.
Daniel
omnidan
  • 2,055
If it's something in your gnome settings that has gone wrong, you could reset them to defaults using Ubuntu Tweak. If you open Ubuntu Tweak and then look under the "Desktop Recovery" section you can restore any of several settings folders to the initial defaults.
