I cannot install my updates. I used the following information How do I fix a "Failed to download package files" error? but it didn't work.
In the software sources window under the "ubuntu software" tab everything except the source code is checked. Under the "other software" tab I have Canonical Partners and Canonical Partners (Source code) and that's all.
When i try to update my software it says:
Failed to download repository information
Check your Internet connection.
I have ubuntu 12.04LTS
please help
I have the same issue. Software Updater barely tries and then gives up saying to check my internet connection.
It works fine when I do it from the terminal, as lukibeni suggested.
sudo apt-get update
sudo apt-get upgrade
Updating from the terminal I get consistent 100kB/s down, which isn't broadband speeds, but it clearly works just fine, Software Updater. At least for some subset of users, the software updater tool is mostly broken.
I see another answer (https://askubuntu.com/questions/276191/software-updater-wont-update-says-to-check-internet-ubuntu-12-10?rq=1) about going into the software sources options and changing the server you get updates from. That didn't work for me.
dogtato
  • 761
