14
when I try to launch VMWARE-WORKSTATION, I get the following error:
Before you can run VMware, several modules must be compiled and loaded into the kernel CANCEL / INSTALL
No errors, when I select INSTALL nothing happens just closes.
I install manually:
sudo apt-get install open-vm-tools open-vm-tools-dev open-vm-dkms open-vm-toolbox open-vm-tools-dev
But already installed to the latest versions.
I will start a bounty to fix this.
Ubuntu 13.04 64bit
pst007x@pst007x-Serval-Professional:~$ uname -a
Linux pst007x-Serval-Professional 3.9.0-030900-generic #201304291257 SMP Mon Apr 29 16:58:15 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
I have uninstalled and reinstalled all components, but same problem.
I have tried a different Kernel, but end up with the same problem.
Tried this as suggested: here
#!/bin/bash
cd
cp -prn /usr/lib/vmware/modules/source /usr/lib/vmware/modules/source-backup
mkdir fixed
cd fixed
find /usr/lib/vmware/modules/source -name "*.tar" -exec tar xf '{}' \;
## add missing header on kernels
sed -i '/#include "compat_wait.h"/a\#include "compat_sched.h"' vmnet-only/vnetUserListener.c
sed -i '/#include "compat_page.h"/a\#include "compat_sched.h"' vmci-only/include/pgtbl.h
## comment out an invalid definition
sed -i 's|\(extern void poll_initwait(compat_poll_wqueues \*);\)|//\1|' *-only/include/compat_wait.h
tar cf vmblock.tar vmblock-only
tar cf vmci.tar vmci-only
tar cf vmmon.tar vmmon-only
tar cf vmnet.tar vmnet-only
tar cf vmppuser.tar vmppuser-only
tar cf vsock.tar vsock-only
cp -p *.tar /usr/lib/vmware/modules/source
cd /lib/modules/`uname -r`/build/include/linux
ln -s ../generated/autoconf.h
ln -s ../generated/utsrelease.h
cd
vmware-modconfig --console --install-all
# clean up
cd
rm -rf fixed
rm autoconf.h utsrelease.h
cd /usr/lib/vmware/modules/
rm -rf source-backup
cd
Didn't work, results of script in terminal:
pst007x@pst007x-Serval-Professional:~/Desktop$ sudo ./run
[sudo] password for pst007x:
sed: can't read vmci-only/include/pgtbl.h: No such file or directory
sed: can't read *-only/include/compat_wait.h: No such file or directory
tar: vmppuser-only: Cannot stat: No such file or directory
tar: Exiting with failure status due to previous errors
ln: failed to create symbolic link ‘./autoconf.h’: File exists
ln: failed to create symbolic link ‘./utsrelease.h’: File exists
Stopping VMware services:
   VMware Authentication Daemon                                        done
   VM communication interface socket family                            done
   Virtual machine communication interface                             done
   Virtual machine monitor                                             done
   Blocking file system                                                done
Using 2.6.x kernel build system.
make: Entering directory `/tmp/modconfig-tGleah/vmmon-only'
/usr/bin/make -C /lib/modules/3.9.0-030900-generic/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. \
      MODULEBUILDDIR= modules
make[1]: Entering directory `/usr/src/linux-headers-3.9.0-030900-generic'
  CC [M]  /tmp/modconfig-tGleah/vmmon-only/linux/driver.o
  CC [M]  /tmp/modconfig-tGleah/vmmon-only/linux/driverLog.o
  CC [M]  /tmp/modconfig-tGleah/vmmon-only/linux/hostif.o
  CC [M]  /tmp/modconfig-tGleah/vmmon-only/common/apic.o
  CC [M]  /tmp/modconfig-tGleah/vmmon-only/common/comport.o
  CC [M]  /tmp/modconfig-tGleah/vmmon-only/common/cpuid.o
  CC [M]  /tmp/modconfig-tGleah/vmmon-only/common/hashFunc.o
  CC [M]  /tmp/modconfig-tGleah/vmmon-only/common/memtrack.o
  CC [M]  /tmp/modconfig-tGleah/vmmon-only/common/phystrack.o
  CC [M]  /tmp/modconfig-tGleah/vmmon-only/common/task.o
  CC [M]  /tmp/modconfig-tGleah/vmmon-only/common/vmx86.o
  CC [M]  /tmp/modconfig-tGleah/vmmon-only/vmcore/moduleloop.o
  LD [M]  /tmp/modconfig-tGleah/vmmon-only/vmmon.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /tmp/modconfig-tGleah/vmmon-only/vmmon.mod.o
  LD [M]  /tmp/modconfig-tGleah/vmmon-only/vmmon.ko
make[1]: Leaving directory `/usr/src/linux-headers-3.9.0-030900-generic'
/usr/bin/make -C $PWD SRCROOT=$PWD/. \
      MODULEBUILDDIR= postbuild
make[1]: Entering directory `/tmp/modconfig-tGleah/vmmon-only'
make[1]: `postbuild' is up to date.
make[1]: Leaving directory `/tmp/modconfig-tGleah/vmmon-only'
cp -f vmmon.ko ./../vmmon.o
make: Leaving directory `/tmp/modconfig-tGleah/vmmon-only'
make: Entering directory `/tmp/modconfig-tGleah/vmnet-only'
  CC [M]  /tmp/modconfig-tGleah/vmnet-only/driver.o
  CC [M]  /tmp/modconfig-tGleah/vmnet-only/hub.o
  CC [M]  /tmp/modconfig-tGleah/vmnet-only/userif.o
  CC [M]  /tmp/modconfig-tGleah/vmnet-only/netif.o
  CC [M]  /tmp/modconfig-tGleah/vmnet-only/bridge.o
  CC [M]  /tmp/modconfig-tGleah/vmnet-only/filter.o
  CC [M]  /tmp/modconfig-tGleah/vmnet-only/procfs.o
  CC [M]  /tmp/modconfig-tGleah/vmnet-only/smac_compat.o
  CC [M]  /tmp/modconfig-tGleah/vmnet-only/smac.o
  CC [M]  /tmp/modconfig-tGleah/vmnet-only/vnetEvent.o
  CC [M]  /tmp/modconfig-tGleah/vmnet-only/vnetUserListener.o
  LD [M]  /tmp/modconfig-tGleah/vmnet-only/vmnet.o
  MODPOST 1 modules
  CC      /tmp/modconfig-tGleah/vmnet-only/vmnet.mod.o
  LD [M]  /tmp/modconfig-tGleah/vmnet-only/vmnet.ko
make[1]: Entering directory `/tmp/modconfig-tGleah/vmnet-only'
make[1]: Leaving directory `/tmp/modconfig-tGleah/vmnet-only'
cp -f vmnet.ko ./../vmnet.o
make: Leaving directory `/tmp/modconfig-tGleah/vmnet-only'
make: Entering directory `/tmp/modconfig-tGleah/vmblock-only'
  CC [M]  /tmp/modconfig-tGleah/vmblock-only/linux/block.o
  CC [M]  /tmp/modconfig-tGleah/vmblock-only/linux/control.o
  CC [M]  /tmp/modconfig-tGleah/vmblock-only/linux/dentry.o
  CC [M]  /tmp/modconfig-tGleah/vmblock-only/linux/file.o
  CC [M]  /tmp/modconfig-tGleah/vmblock-only/linux/filesystem.o
  CC [M]  /tmp/modconfig-tGleah/vmblock-only/linux/inode.o
  CC [M]  /tmp/modconfig-tGleah/vmblock-only/linux/module.o
  CC [M]  /tmp/modconfig-tGleah/vmblock-only/linux/stubs.o
/tmp/modconfig-tGleah/vmblock-only/linux/dentry.c:38:4: warning: initialisation from incompatible pointer type [enabled by default]
/tmp/modconfig-tGleah/vmblock-only/linux/dentry.c:38:4: warning: (near initialisation for ‘LinkDentryOps.d_revalidate’) [enabled by default]
/tmp/modconfig-tGleah/vmblock-only/linux/dentry.c: In function ‘DentryOpRevalidate’:
/tmp/modconfig-tGleah/vmblock-only/linux/dentry.c:104:7: warning: passing argument 2 of ‘actualDentry->d_op->d_revalidate’ makes integer from pointer without a cast [enabled by default]
/tmp/modconfig-tGleah/vmblock-only/linux/dentry.c:104:7: note: expected ‘unsigned int’ but argument is of type ‘struct nameidata *’
  CC [M]  /tmp/modconfig-tGleah/vmblock-only/linux/super.o
/tmp/modconfig-tGleah/vmblock-only/linux/control.c: In function ‘ExecuteBlockOp’:
/tmp/modconfig-tGleah/vmblock-only/linux/control.c:285:9: warning: assignment from incompatible pointer type [enabled by default]
/tmp/modconfig-tGleah/vmblock-only/linux/control.c:296:4: warning: passing argument 1 of ‘putname’ from incompatible pointer type [enabled by default]
In file included from include/linux/proc_fs.h:5:0,
                 from /tmp/modconfig-tGleah/vmblock-only/linux/control.c:28:
include/linux/fs.h:2040:13: note: expected ‘struct filename *’ but argument is of type ‘char *’
/tmp/modconfig-tGleah/vmblock-only/linux/inode.c:49:4: warning: initialisation from incompatible pointer type [enabled by default]
/tmp/modconfig-tGleah/vmblock-only/linux/inode.c:49:4: warning: (near initialisation for ‘RootInodeOps.lookup’) [enabled by default]
  LD [M]  /tmp/modconfig-tGleah/vmblock-only/vmblock.o
  MODPOST 1 modules
WARNING: "putname" [/tmp/modconfig-tGleah/vmblock-only/vmblock.ko] undefined!
  CC      /tmp/modconfig-tGleah/vmblock-only/vmblock.mod.o
  LD [M]  /tmp/modconfig-tGleah/vmblock-only/vmblock.ko
make[1]: Entering directory `/tmp/modconfig-tGleah/vmblock-only'
make[1]: Leaving directory `/tmp/modconfig-tGleah/vmblock-only'
cp -f vmblock.ko ./../vmblock.o
make: Leaving directory `/tmp/modconfig-tGleah/vmblock-only'
make: Entering directory `/tmp/modconfig-tGleah/vmci-only'
  CC [M]  /tmp/modconfig-tGleah/vmci-only/linux/driver.o
  CC [M]  /tmp/modconfig-tGleah/vmci-only/linux/vmciKernelIf.o
  CC [M]  /tmp/modconfig-tGleah/vmci-only/common/vmciContext.o
  CC [M]  /tmp/modconfig-tGleah/vmci-only/common/vmciDoorbell.o
  CC [M]  /tmp/modconfig-tGleah/vmci-only/common/vmciDriver.o
  CC [M]  /tmp/modconfig-tGleah/vmci-only/common/vmciDatagram.o
  CC [M]  /tmp/modconfig-tGleah/vmci-only/common/vmciEvent.o
  CC [M]  /tmp/modconfig-tGleah/vmci-only/common/vmciHashtable.o
/tmp/modconfig-tGleah/vmci-only/linux/driver.c:127:4: error: implicit declaration of function ‘__devexit_p’ [-Werror=implicit-function-declaration]
/tmp/modconfig-tGleah/vmci-only/linux/driver.c:127:4: error: initialiser element is not constant
/tmp/modconfig-tGleah/vmci-only/linux/driver.c:127:4: error: (near initialisation for ‘vmci_driver.remove’)
/tmp/modconfig-tGleah/vmci-only/linux/driver.c:1754:1: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘vmci_probe_device’
/tmp/modconfig-tGleah/vmci-only/linux/driver.c:1982:1: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘vmci_remove_device’
/tmp/modconfig-tGleah/vmci-only/linux/driver.c:119:12: warning: ‘vmci_probe_device’ used but never defined [enabled by default]
/tmp/modconfig-tGleah/vmci-only/linux/driver.c:121:13: warning: ‘vmci_remove_device’ used but never defined [enabled by default]
/tmp/modconfig-tGleah/vmci-only/linux/driver.c:2063:1: warning: ‘vmci_interrupt’ defined but not used [-Wunused-function]
/tmp/modconfig-tGleah/vmci-only/linux/driver.c:2137:1: warning: ‘vmci_interrupt_bm’ defined but not used [-Wunused-function]
/tmp/modconfig-tGleah/vmci-only/linux/driver.c:1717:1: warning: ‘vmci_enable_msix’ defined but not used [-Wunused-function]
cc1: some warnings being treated as errors
make[2]: *** [/tmp/modconfig-tGleah/vmci-only/linux/driver.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [_module_/tmp/modconfig-tGleah/vmci-only] Error 2
make: *** [vmci.ko] Error 2
make: Leaving directory `/tmp/modconfig-tGleah/vmci-only'
Unable to install all modules.  See log for details.
Tried as suggested below, but same issue:
pst007x@pst007x-Serval-Professional:~$ sudo vmware-modconfig --console --install-all
make: Entering directory `/tmp/modconfig-IFjtiM/vmmon-only'
  CC [M]  /tmp/modconfig-IFjtiM/vmmon-only/linux/driver.o
  CC [M]  /tmp/modconfig-IFjtiM/vmmon-only/linux/driverLog.o
  CC [M]  /tmp/modconfig-IFjtiM/vmmon-only/linux/hostif.o
  CC [M]  /tmp/modconfig-IFjtiM/vmmon-only/common/apic.o
  CC [M]  /tmp/modconfig-IFjtiM/vmmon-only/common/comport.o
  CC [M]  /tmp/modconfig-IFjtiM/vmmon-only/common/cpuid.o
  CC [M]  /tmp/modconfig-IFjtiM/vmmon-only/common/hashFunc.o
  CC [M]  /tmp/modconfig-IFjtiM/vmmon-only/common/memtrack.o
  CC [M]  /tmp/modconfig-IFjtiM/vmmon-only/common/phystrack.o
  CC [M]  /tmp/modconfig-IFjtiM/vmmon-only/common/task.o
  CC [M]  /tmp/modconfig-IFjtiM/vmmon-only/common/vmx86.o
  CC [M]  /tmp/modconfig-IFjtiM/vmmon-only/vmcore/moduleloop.o
  LD [M]  /tmp/modconfig-IFjtiM/vmmon-only/vmmon.o
  MODPOST 1 modules
  CC      /tmp/modconfig-IFjtiM/vmmon-only/vmmon.mod.o
  LD [M]  /tmp/modconfig-IFjtiM/vmmon-only/vmmon.ko
make[1]: Entering directory `/tmp/modconfig-IFjtiM/vmmon-only'
make[1]: Leaving directory `/tmp/modconfig-IFjtiM/vmmon-only'
make: Leaving directory `/tmp/modconfig-IFjtiM/vmmon-only'
make: Entering directory `/tmp/modconfig-IFjtiM/vmnet-only'
  CC [M]  /tmp/modconfig-IFjtiM/vmnet-only/driver.o
  CC [M]  /tmp/modconfig-IFjtiM/vmnet-only/hub.o
  CC [M]  /tmp/modconfig-IFjtiM/vmnet-only/userif.o
  CC [M]  /tmp/modconfig-IFjtiM/vmnet-only/netif.o
  CC [M]  /tmp/modconfig-IFjtiM/vmnet-only/bridge.o
  CC [M]  /tmp/modconfig-IFjtiM/vmnet-only/filter.o
  CC [M]  /tmp/modconfig-IFjtiM/vmnet-only/procfs.o
  CC [M]  /tmp/modconfig-IFjtiM/vmnet-only/smac_compat.o
  CC [M]  /tmp/modconfig-IFjtiM/vmnet-only/smac.o
  CC [M]  /tmp/modconfig-IFjtiM/vmnet-only/vnetEvent.o
  CC [M]  /tmp/modconfig-IFjtiM/vmnet-only/vnetUserListener.o
  LD [M]  /tmp/modconfig-IFjtiM/vmnet-only/vmnet.o
  MODPOST 1 modules
  CC      /tmp/modconfig-IFjtiM/vmnet-only/vmnet.mod.o
  LD [M]  /tmp/modconfig-IFjtiM/vmnet-only/vmnet.ko
make[1]: Entering directory `/tmp/modconfig-IFjtiM/vmnet-only'
make[1]: Leaving directory `/tmp/modconfig-IFjtiM/vmnet-only'
make: Leaving directory `/tmp/modconfig-IFjtiM/vmnet-only'
make: Entering directory `/tmp/modconfig-IFjtiM/vmblock-only'
  CC [M]  /tmp/modconfig-IFjtiM/vmblock-only/linux/block.o
  CC [M]  /tmp/modconfig-IFjtiM/vmblock-only/linux/control.o
  CC [M]  /tmp/modconfig-IFjtiM/vmblock-only/linux/dentry.o
  CC [M]  /tmp/modconfig-IFjtiM/vmblock-only/linux/file.o
  CC [M]  /tmp/modconfig-IFjtiM/vmblock-only/linux/filesystem.o
  CC [M]  /tmp/modconfig-IFjtiM/vmblock-only/linux/inode.o
  CC [M]  /tmp/modconfig-IFjtiM/vmblock-only/linux/module.o
  CC [M]  /tmp/modconfig-IFjtiM/vmblock-only/linux/stubs.o
/tmp/modconfig-IFjtiM/vmblock-only/linux/control.c: In function ‘ExecuteBlockOp’:
/tmp/modconfig-IFjtiM/vmblock-only/linux/control.c:285:9: warning: assignment from incompatible pointer type [enabled by default]
/tmp/modconfig-IFjtiM/vmblock-only/linux/control.c:296:4: warning: passing argument 1 of ‘putname’ from incompatible pointer type [enabled by default]
                 from /tmp/modconfig-IFjtiM/vmblock-only/linux/control.c:28:
/tmp/modconfig-IFjtiM/vmblock-only/linux/dentry.c:38:4: warning: initialisation from incompatible pointer type [enabled by default]
/tmp/modconfig-IFjtiM/vmblock-only/linux/dentry.c:38:4: warning: (near initialisation for ‘LinkDentryOps.d_revalidate’) [enabled by default]
/tmp/modconfig-IFjtiM/vmblock-only/linux/dentry.c: In function ‘DentryOpRevalidate’:
/tmp/modconfig-IFjtiM/vmblock-only/linux/dentry.c:104:7: warning: passing argument 2 of ‘actualDentry->d_op->d_revalidate’ makes integer from pointer without a cast [enabled by default]
/tmp/modconfig-IFjtiM/vmblock-only/linux/dentry.c:104:7: note: expected ‘unsigned int’ but argument is of type ‘struct nameidata *’
/tmp/modconfig-IFjtiM/vmblock-only/linux/inode.c:49:4: warning: initialisation from incompatible pointer type [enabled by default]
/tmp/modconfig-IFjtiM/vmblock-only/linux/inode.c:49:4: warning: (near initialisation for ‘RootInodeOps.lookup’) [enabled by default]
  CC [M]  /tmp/modconfig-IFjtiM/vmblock-only/linux/super.o
  LD [M]  /tmp/modconfig-IFjtiM/vmblock-only/vmblock.o
  MODPOST 1 modules
WARNING: "putname" [/tmp/modconfig-IFjtiM/vmblock-only/vmblock.ko] undefined!
  CC      /tmp/modconfig-IFjtiM/vmblock-only/vmblock.mod.o
  LD [M]  /tmp/modconfig-IFjtiM/vmblock-only/vmblock.ko
make[1]: Entering directory `/tmp/modconfig-IFjtiM/vmblock-only'
make[1]: Leaving directory `/tmp/modconfig-IFjtiM/vmblock-only'
make: Leaving directory `/tmp/modconfig-IFjtiM/vmblock-only'
make: Entering directory `/tmp/modconfig-IFjtiM/vmci-only'
  CC [M]  /tmp/modconfig-IFjtiM/vmci-only/linux/driver.o
  CC [M]  /tmp/modconfig-IFjtiM/vmci-only/linux/vmciKernelIf.o
  CC [M]  /tmp/modconfig-IFjtiM/vmci-only/common/vmciContext.o
  CC [M]  /tmp/modconfig-IFjtiM/vmci-only/common/vmciDatagram.o
  CC [M]  /tmp/modconfig-IFjtiM/vmci-only/common/vmciDoorbell.o
  CC [M]  /tmp/modconfig-IFjtiM/vmci-only/common/vmciDriver.o
  CC [M]  /tmp/modconfig-IFjtiM/vmci-only/common/vmciHashtable.o
  CC [M]  /tmp/modconfig-IFjtiM/vmci-only/common/vmciEvent.o
/tmp/modconfig-IFjtiM/vmci-only/linux/driver.c:127:4: error: implicit declaration of function ‘__devexit_p’ [-Werror=implicit-function-declaration]
/tmp/modconfig-IFjtiM/vmci-only/linux/driver.c:127:4: error: initialiser element is not constant
/tmp/modconfig-IFjtiM/vmci-only/linux/driver.c:127:4: error: (near initialisation for ‘vmci_driver.remove’)
/tmp/modconfig-IFjtiM/vmci-only/linux/driver.c:1754:1: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘vmci_probe_device’
/tmp/modconfig-IFjtiM/vmci-only/linux/driver.c:1982:1: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘vmci_remove_device’
/tmp/modconfig-IFjtiM/vmci-only/linux/driver.c:119:12: warning: ‘vmci_probe_device’ used but never defined [enabled by default]
/tmp/modconfig-IFjtiM/vmci-only/linux/driver.c:121:13: warning: ‘vmci_remove_device’ used but never defined [enabled by default]
/tmp/modconfig-IFjtiM/vmci-only/linux/driver.c:2063:1: warning: ‘vmci_interrupt’ defined but not used [-Wunused-function]
/tmp/modconfig-IFjtiM/vmci-only/linux/driver.c:2137:1: warning: ‘vmci_interrupt_bm’ defined but not used [-Wunused-function]
/tmp/modconfig-IFjtiM/vmci-only/linux/driver.c:1717:1: warning: ‘vmci_enable_msix’ defined but not used [-Wunused-function]
make[2]: *** [/tmp/modconfig-IFjtiM/vmci-only/linux/driver.o] Error 1
make[1]: *** [_module_/tmp/modconfig-IFjtiM/vmci-only] Error 2
make: Leaving directory `/tmp/modconfig-IFjtiM/vmci-only'
pst007x@pst007x-Serval-Professional:~$ sudo apt-get install build-essential
Reading package lists... Done
Building dependency tree
build-essential is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Moderator: I have tried all suggestions in other posts, but they do not address this particular issue.
This is not a duplicate, the other postings do not address this specific issue and offer no solutions
pst007x
  • 8,210
5 Answers5
12
I has same problem. After some joojling(googling), i resolved my problem ny following steps:
  1. (I am not sure that this does any affect about my problem) as @pst007x executed
    cd /lib/modules/$(uname -r)/build/include/linux
    sudo ln -s ../generated/utsrelease.h
    sudo ln -s ../generated/autoconf.h
    sudo ln -s ../generated/uapi/linux/version.h
  2. I ran following code as @Qasim suggested
I have Ubuntu 13.04-64bit, powered by kernel 3.8.0-21-generic and VMware Player 5.0.2 build-1031769
Good luck!
S.M.Mousavi
  • 1,176
I believe the issue is that you have the wrong kernel headers, it looks like one of those suggestions is trying to use kernel headers for 3.9.0, doesn't 13.04 use kernel version 3.88 ? Try getting the kernel headers from apt, do:
sudo apt-get install linux-headers-$(uname -r) (borrowed from nixCraft)
and then try to install it again
I had the exact same problem when I upgraded from 12.10 to 13.04. When I started VMware I would get the same message:
When I would click INSTALL then nothing would happen. I checked /var/log/ and apport was reporting the following error:
ERROR: apport (pid 3061) Thu Apr 25 08:48:51 2013: executable: /usr/lib/vmware/bin/appLoader (command line "/usr/lib/vmware/bin/vmware-gksu --sudo-mode --message=Please\ enter\ your\ password\ to\ proceed. '/usr/bin/vmware-modconfig'\ --icon='vmware-workstation'\ --appname='VMware'")
There appears to be an issue with /usr/lib/vmware/bin/vmware-gksu that causes it to crash. I can reliably reproduce the problem everytime I run the command. I was able to solve the problem by running the command manually. Here are the commands I ran:
sudo apt-get install linux-headers-3.8.0-19-generic
sudo /usr/bin/vmware-modconfig --icon=vmware-workstation --appname=VMware
Do you see something similar in /var/log/apport?
notkevin
  • 731
I had the same problem, combining some solutions above worked for me, I'm a developer so I already had the most recent linux headers, but just in case you don't
A couple of errors were thrown, despite them it's now working perfectly.
It should be noted that this method was tested with VMWare Player, not workstation (my workstation key is out of date, the latest I have is version 7)
Felps
I have found a solution which worked for me here:
git clone -b workstation-15.0.2 https://github.com/mkubecek/vmware-host-modules.git
cd vmware-host-modules
tar -cf vmmon.tar vmmon-only
tar -cf vmnet.tar vmnet-only
sudo cp -v vmmon.tar vmnet.tar /usr/lib/vmware/modules/source/
You can replace the Workstation version with the current version in the git repository name above.
sequence
  • 200
