It asks for the newest kernel headers (3.8.0-21-generic), so I downloaded them. After pointing to the new path for the file it still does not work. I have tried many solutions but none were successful. This is my first time posting a question, so please tell me if you need more information. Thanks in advance!
I have followed [these instructions] (Unable to start VMWare Workstation after upgrade to 13.04) but "sudo ln -s ../generated/uapi/linux/version.h" yields, "ln: failed to create symbolic link ‘./utsrelease.h’: File exists". So I ran, "sudo ln -sf ../generated/uapi/linux/version.h" but it doesn't appear to do anything.
I tried https://askubuntu.com/a/296551/159739 but I get, "ln: failed to create symbolic link ‘./version.h’: File exists"
UPDATE:
Now when I try to launch VMware a pop up reads, "Before you can run VMware, several modules must be compiled and loaded into the running kernel." CANCEL/INSTALL. When I select to install it just closes.
This solution was taken from this answer. However, that answer is still not marked as accepted, but it worked for me.
Run the following script:
#!/bin/bash
if [[ $UID != 0 ]]; then
    echo "Please run this script with sudo:"
    echo "sudo $0 $*"
    exit 1
fi
sudo ln -s /usr/src/linux-headers-$(uname -r)/include/generated/uapi/linux/version.h /usr/src/linux-headers-$(uname -r)/include/linux/version.h
cd /usr/lib/vmware/modules/source
sudo tar -xf vmci.tar
cd vmci-only/linux
sudo sed '127s/.*/   .remove = vmci_remove_device,/' driver.c > driver.c.tmp
mv driver.c.tmp driver.c
sudo sed '1753s/.*/static int/' driver.c > driver.c.tmp
sudo sed '1981s/.*/static void/' driver.c > driver.c.tmp
cd ../..
sudo tar -cf vmci.tar vmci-only/
sudo rm vmci-only/ -Rf
sudo vmware-modconfig --console --install-all
sudo rm /usr/src/linux-headers-$(uname -r)/include/linux/version.h
echo "Done"
Alaa Ali
  • 32,213
