What is main differences between running Ubuntu on LiveUSB (created with Startup Disk Creator with persistent storage) and install Ubuntu to partitions on USB disk?
I love LiveUSB but I can't put password on it, and it's a pain if I need to click Try Ubuntu everytime.
If I just complete install Ubuntu to USB disk, is there any performance issue? And, will it run on almost any computer like LiveUSB do?
Nur
  • 4,131
There are two differences.
First LiveUSB is meant to be run that way. You boot the best way for USB, you access the best way for USB and your "partition" the best way for USB (even if you don't actually do it your self). Installing Ubuntu to a USB disk will not let Ubuntu know to take special precautions because your using a removable disk. Most notable liveUSB stores the root file system in RAM where an installed instance the root partition would be on disk.
Second, booting to USB takes a special setup. Not saying that Linux can't do it, but it could get a bit harry around the time when grub tries to install or update. Most usb installs will use something like ISOLinux or similar to allow booting. UMS drivers may or may not work from the BIOS/EFI level to allow you to boot a normal system. In short, installing and booting Ubuntu from a USB drive could be more of a PIA then it's worth in regards to booting or updating the booting.
As a side note, you will need etx3 and USB modules complied into the kernel to boot a root file system from USB. I am not sure they are (the USB ones) by default. --This is a side note because they may be modules included in initramfs, I just don't know but if your going to boot root from USB then your going to have to find out.
coteyr
  • 18,724
Short and Sweet -
Live USB is nothing but running Ubuntu like a Live CD. Changes wont be saved, etc,etc.
While if u install Ubuntu on a USB, it is just like having Ubuntu Installed on a HardDisk!
I have used the 2nd option many times, and it gives u the best portable OS ever!
Performance... yes it will run a little slower than usual on USB 2.0
on USB 3.0 its fast enough, provided you don't clutter it with too many installs and data.
Needless to say, your USB life expectancy will be reduced as there will be immense number of Read/Write cycles(it still isnt too less)
I would suggest you a USB Install instead of Live USB.
Hope you know the procedure. If not, post another question(for better understanding for people who refer later) and you will get a guide easily! :)
Thankyou :)
Nirmik
  • 7,938
There are three main alternatives to run Ubuntu from a USB drive,
  • live-only
  • persistent live
  • installed system
A persistent live system is an alternative 'between' a live-only system and an installed system (installed like in an internal drive, but in a USB drive). You can save files, you can install some application program packages, but there are limits, for example, you cannot install a new kernel.
See the following link and links from it for more details,
Bootable USB Ubuntu on Windows
sudodus
  • 47,684
