I used to use gksudo gedit /etc/something.conf to edit system configuration files but this doesn't seem to work any more. Looks like there is no gksudo in 13.04. How can I add it back or what am I intended to use instead?
Asked
Active
Viewed 9.9k times
16
Yes, there is NO gksudo available for Ubuntu 13.04. It has been removed.
So, you can use 'sudo' instead. Just type: sudo -i gedit /etc/something.conf. You will be asked for your password.
If you are not comfortable with it, use this sudo apt-get install gksu to install gksu, and you can use the gksudo command.
10
Thanks to thefourtheye's link I've found the answer and am sharing it here for further reference:
The package name is gksu so the answer to the actual question is
However, one should probably consider reading PSA: gksu is no longer installed by default and Why is gksu no longer installed by default in 13.04? if interested in this question.
