I'm trying to update but it can't and tells me that I need to clear up space in the boot directory but I can't remove anything from it and the sudo command does nothing. Below is the actual message I get.
The upgrade needs a total of 26.0 M free space on disk '/boot'. Please free at least an additional 5,055 k of disk space on '/boot'. Empty your trash and remove temporary packages of former installations using 'sudo apt-get clean'.
Please help, oh BTW, yes I'm fairly new to Linux so please bear with me.
It's probably because you have too many kernel packages installed (you can only run one at a time).
Check which kernel packages are installed:
dpkg -l 'linux-image*' | grep '^ii'
Check what your current kernel is:
uname -r
And just remove the older versions. For instance on my machine my /boot directory contents looks like this:
% ls -al /boot
drwxr-xr-x  4 root root     1024 May  2 13:00 .
drwxr-xr-x 27 root root     4096 Apr 18 01:09 ..
-rw-------  1 root root  3018381 Mar 11 22:39 System.map-3.5.0-26-generic
-rw-------  1 root root  3020028 Mar 26 19:54 System.map-3.5.0-27-generic
-rw-------  1 root root  3020830 Apr 24 23:04 System.map-3.5.0-28-generic
-rw-r--r--  1 root root   850088 Mar 11 22:39 abi-3.5.0-26-generic
-rw-r--r--  1 root root   852365 Mar 26 19:54 abi-3.5.0-27-generic
-rw-r--r--  1 root root   852490 Apr 24 23:04 abi-3.5.0-28-generic
-rw-r--r--  1 root root   147953 Mar 11 22:39 config-3.5.0-26-generic
-rw-r--r--  1 root root   148105 Mar 26 19:54 config-3.5.0-27-generic
-rw-r--r--  1 root root   148105 Apr 24 23:04 config-3.5.0-28-generic
drwxr-xr-x  3 root root     5120 May  2 13:01 grub
-rw-------  1 root root 23540031 Mar 28 18:31 initrd.img-3.5.0-26-generic
-rw-------  1 root root 23574269 Apr  9 08:26 initrd.img-3.5.0-27-generic
-rw-------  1 root root 23578154 May  2 13:00 initrd.img-3.5.0-28-generic
drwxr-xr-x  2 root root    12288 Oct  5  2012 lost+found
-rw-r--r--  1 root root   176764 Nov 27  2011 memtest86+.bin
-rw-r--r--  1 root root   178944 Nov 27  2011 memtest86+_multiboot.bin
-rw-------  1 root root  5180064 Mar 11 22:39 vmlinuz-3.5.0-26-generic
-rw-------  1 root root  5180864 Mar 26 19:54 vmlinuz-3.5.0-27-generic
-rw-------  1 root root  5183296 Apr 24 23:04 vmlinuz-3.5.0-28-generic
I have the following kernel image packages installed:
% dpkg -l 'linux-image*' | grep '^ii'
ii  linux-image-3.5.0-26-generic                      3.5.0-26.42~precise1                                Linux kernel image for version 3.5.0 on 64 bit x86 SMP
ii  linux-image-3.5.0-27-generic                      3.5.0-27.46~precise1                                Linux kernel image for version 3.5.0 on 64 bit x86 SMP
ii  linux-image-3.5.0-28-generic                      3.5.0-28.48~precise1                                Linux kernel image for version 3.5.0 on 64 bit x86 SMP
ii  linux-image-generic-lts-quantal                   3.5.0.28.35                                         Generic Linux kernel image
And my currently running kernel is:
% uname -r
3.5.0-27-generic
Thus, in my case I could free up space in /boot by removing:
by running apt-get remove <package_name>
You can remove ALL the old kernels, and keep just the latest one. This will free up space on /boot. This is doable via multiple methods.
Refer this link. User mikewhatever has provided an answer which can do this removal from one single command from command line.
Update: listing the command here itself, from the said link:
sudo apt-get remove --purge $(dpkg -l 'linux-*' | sed '/^ii/!d;/'"$(uname -r | sed "s/\(.*\)-\([^0-9]\+\)/\1/")"'/d;s/^[^ ]* [^ ]* \([^ ]*\).*/\1/;/[0-9]/!d')
Bhavin Doshi
  • 2,496
