i've download and installed ubuntu 13.4
mostly every thing work but i have a problem in the sound !
when i run some song the sound work perfectly but when i connect my head set i have no sound
running UBUNTU 13.4 on HP-pavilion dv6-6c65se
best regards.,
IraqNux
  • 13
l have HP dv6 and was having the same problem. l fixed it by terminal / alsamixer.
Open a terminal. (The quickest way is the Ctrl-Alt-T shortcut.) Enter alsamixer” and press the Enter key. You will now see a user interface. In this user interface, you can do the following:
  1. Select your correct sound card using F6 and select F5 to see recording controls as well
  2. Move around with left arrow and right arrow keys.
  3. Increase and decrease volume with up and down arrow keys.
  4. Mute / Unmute with the M key. An MM means muted, and OO means unmuted.
  5. Exit from alsamixer with the Esc key.
A caveat here: When you mute or unmute something, pulseaudio might pick it up and mute and unmute other controls, as well as PulseAudio’s main mute.
BuZZ-dEE
  • 14,533
andreas
  • 26
