I had installed bumblebee 3.0 for my nVidia geforce 635M card in ubuntu 12.10 and got instant results - temp ad fan speeds reduced, batt backup extended to almost 6 hrs. (from 1.5-2 hrs earlier) and upon comparing glxspheres with and without optirun, got the fps to jump from ~60 to ~130.
But when bumblebee updated to version 3.2, I suppose it updated fine and was active, but the batt life reduced to about 4 hrs. Also optirun glxspheres gave an fps of ~60, although it did recognize the nvidia card and mentioned it in the output.
is this a bug or some limitation on 3.2? should i revert to using 3.0?, and if so, how to fix it.
PLease help as I loved the long batt backup and higher fps earlier.
Also, I saw in some post on the internet that someone got an fps in the range of 1300 - 1600 fps after starting nvidia hardware acceleration whereas I had got only 130 fps...whats the catch there?
charlie
  • 1,792
Disable card on boot
These options can be useful to disable the card on boot time. in /etc/modules file can be used to load modules on boot time. Adding the below line to the file makes the card get disabled on boot:
 bbswitch load_state=0
You have to update your initial ramdisk (initrd) for the changes propagate to the boot process. On Debian and Ubuntu, this can performed by running update-initramfs -u as root.
Disable card on exit
Edit the line in /etc/bumblebee/bumblebee.conf, Set it to true, By default it set it to false
 TurnCardOffAtExit=true
I hope this work for you ....
Also please check Is there a power saving application similar to Jupiter?
Qasim
  • 22,162
Thanks Qasim for the news, bumblebee 3.2.1 released with bugfixes specially for Ubuntu Raring Ringtail 13.04 solved all the perf issues.
https://raw.github.com/Bumblebee-Project/Bumblebee/master/doc/RELEASE_NOTES_3_2_1
charlie
  • 1,792
