17
I would like to add a starter icon to my task bar that runs dolphin but initially starts in a folder I would like to specify
the Dolphin Handbook doesn't explain this.
don.joey
  • 29,392
rubo77
  • 34,024
  • 52
  • 172
  • 299
5 Answers5
14
Try this in the terminal: dolphin /usr/home/ (choose your own path). For more information, read the man page (also available online: http://manpages.ubuntu.com/manpages/hardy/man1/dolphin.1.html).
don.joey
  • 29,392
If you would like to open dolphin from your current path in your terminal just use,
dolphin . &
neonidian
  • 301
Help pages
The KDE applications have the help - with the Dolphin:
:~$ dolphin --help
Usage: dolphin [Qt-options] [KDE-options] [options] [Url]
File Manager
Generic options:
  --help                    Show help about options
  --help-qt                 Show Qt specific options
  --help-kde                Show KDE specific options
  --help-all                Show all options
  --author                  Show author information
  -v, --version             Show version information
  --license                 Show license information
  --                        End of options
Options:
  --select                  The files and directories passed as arguments will be selected.
  --split                   Dolphin will get started with a split view.
Arguments:
  Url                       Document to open
Launch with the default application
The KDE has the "Default Appications" in the KDE system settings.
The kfmclient is:
:~$ kfmclient --help
Usage: kfmclient [Qt-options] [KDE-options] [KDE-tempfile-options] [options] command [URL(s)]
KDE tool for opening URLs from the command line
Generic options:
  --help-kde-tempfile       Show KDE-tempfile specific options
  --                        End of options
Options:
  --noninteractive          Non interactive use: no message boxes
  --commands                Show available commands
Arguments:
  command                   Command (see --commands)
  URL(s)                    Arguments for command
Opening the directory with the default file manager:
kfmclient exec /path/to/the/directory/
user26687
  • 15,174
Use --select option, for example
dolphin --select .
dolphin --select /
dolphin --select /path/you/want/.
It won't run as a foreground job in the terminal, so it won't block your terminal session and there is no for & etc and it can take extra arguments
If you want an experience simillar to explorer.exe . from Windows which launches File Explorer in a folder specified by the user and then lets you continue your work in the terminal you can create an executable script and add it to your PATH:
#!/bin/bash
dolphin --new-window "$@" 1>/dev/null 2>/dev/null & disown
Example usage (I called this script explorer):
explorer .
This will open Dolphin's new window in the path specified by the user (e.g. current dir .). All logs will be redirected to /dev/null and the process will be disown which means that you can close the terminal and your Dolphin window will still be open.
Kyriet
  • 111
