Under 13.04, Skype is crashing with a seg fault.
$ skype
Segmentation fault (core dumped)
How can I fix this?
You can also do the following way ...
sudo nano /etc/ld.so.conf.d/skype.conf
copy and paste the following line in it
/usr/lib/i386-linux-gnu/mesa/
and then run
sudo ldconfig -v
This issue was mentioned in the release notes.
Temporary workaround. Open a terminal and paste this in:
sudo mv /usr/bin/skype{,-bin}
sudo install -b -m 744 <(<<EOF
#!/bin/sh
export LD_PRELOAD=/usr/lib/i386-linux-gnu/mesa/libGL.so.1
exec /usr/bin/skype-bin
EOF) /usr/bin/skype
Then Skype should
To get Skype to work in Ubuntu 13.04 Raring Ringtail with proprietary Nvidia / AMD drivers, firstly we'll rename the Skype executable from "skype" to "skype-bin":
sudo mv /usr/bin/skype /usr/bin/skype-bin
Now let's create a file called "skype" under /usr/bin/ - for this we'll launch a text editor as root (I'll use Gedit in the instructions below):
gksu gksu gedit /usr/bin/skype
(I've used "gksu" twice in the command above so Gedit doesn't open a blank tab along with /usr/bin/skype)
And in this file, paste the following:
#!/bin/sh
exec skype-bin "$@"
Then save the file.
And finally, run the following command in a terminal:
sudo chmod 0755 /usr/bin/skype
That's it. Now Skype should work in Ubuntu 13.04 Raring Ringtail.
If you want to revert the changes made by using the instructions above, use these commands:
sudo rm /usr/bin/skype
sudo mv /usr/bin/skype-bin /usr/bin/skype
If you, like me, have Skype installed before upgrading Ubuntu 12.10 to 13.04, uninstall it. Go to Ubuntu Software Center, find Skype and Uninstall.
Add the Ubuntu Partners repository, in Ubuntu Sofware Center, Edit Software Origins, add the following repository:
deb http://archive.canonical.com/ubuntu/ raring partner
Close Sofware Center, then update repository info, from a terminal:
sudo apt-get update
Open Sofware Center again, find and install Skype. You will note that an additional package called Indicator Support for Qt is marked, let it in that way.
