11
Actually this is an answer. Im not asking a question. Last day, I tried to install skype 4.2 on my dell N5110 with nvida Optimus, after the installation when I tried to open skype from dash it didn't open. So then I opened it with Terminal via skype and it gave me an error error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory
So I did the following steps with the help of method mentioned in this link.
Steps:
  1. Open a terminal and type sudo nano /etc/ld.so.conf.d/skype.conf
  2. Add the code /usr/lib/i386-linux-gnu/mesa/ in the next console window, and press ctrl+x to exit, when prompted enter y to say yes
  3. And finally run sudo ldconfig -v
Try this:
Install the package libgl1-mesa-glx:i386
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install libgl1-mesa-glx:i386
Launch Skype via:
LD_PRELOAD=/usr/lib/i386-linux-gnu/mesa/libGL.so.1 skype &
You can put the last statement into a shell script, e.g. ~/bin/skype , or create a .desktop-File with this content:
Name=Skype
Terminal=false
Exec=LD_PRELOAD=/usr/lib/i386-linux-gnu/mesa/libGL.so.1 skype
TargetEnvironment=Unity
UnityLaunchersAndDesktopFiles
Try this (NVIDIA Optimus Ubuntu 13.10):
$sudo update-alternatives --config i386-linux-gnu_gl_conf
  Selection           Path                                      Priority   Status
* 0            /usr/lib/nvidia-331/alt_ld.so.conf         8604      auto mode
  1            /usr/lib/i386-linux-gnu/mesa/ld.so.conf    500       manual mode
  2            /usr/lib/nvidia-331-prime/alt_ld.so.conf   8603      manual mode
  3            /usr/lib/nvidia-331/alt_ld.so.conf         8604      manual mode
Press enter to keep the current choice[*], or type selection number: **1** (Choose native value 1)
$  sudo ldconfig
BuZZ-dEE
  • 14,533
Thomas R's answer is right, but the desktop file did not work for 14.04.1 LTS 64bit.
Here's what works for me:
  1. Edit file /usr/share/applications/skype.desktop
  2. Change the line Exec=env PULSE_LATENCY_MSEC=60 skype %U to Exec=env LD_PRELOAD=/usr/lib/i386-linux-gnu/mesa/libGL.so.1 PULSE_LATENCY_MSEC=60 skype %U
  3. Save file
Here's my complete skype.desktop file:
[Desktop Entry]
Name=Skype
Comment=Skype Internet Telephony
Terminal=false
Type=Application
Encoding=UTF-8
Categories=Network;Application;
MimeType=x-scheme-handler/skype;
X-KDE-Protocols=skype
-1
Have you tried to enter in the terminal:
 sudo apt-get update
and then enter in the terminal:
 sudo apt-get install libgl-mesa-glx:i386
and then enter in the terminal this:
 sudo dpkg-reconfigure -a /etc/ld.so.conf.d/Skype.conf
and it might work fine this way.
Michael
  • 2,597
