We have the following CPU that supports hyper-threading. Though Ubuntu doesn't recognize that each core supports 4 threads.
Intel® Xeon® Processor E5-2407 http://ark.intel.com/products/64614/
The server is a Dell PowerEdge R320 http://www.dell.com/support/Manuals/us/en/19/product/poweredge-r320
The results of lscpu is lscpu
Architecture:          x86_64
CPU op-mode(s):        32-bit, 64-bit
CPU(s):                2
Thread(s) per core:    1
Core(s) per socket:    2
CPU socket(s):         1
NUMA node(s):          1
Vendor ID:             GenuineIntel
CPU family:            6
Model:                 23
Stepping:              10
CPU MHz:               800.000
Virtualization:        VT-x
L1d cache:             32K
L1i cache:             32K
L2 cache:              6144K
I've gone thru and checked the BIOS and I enabled all the features related to virtualization and logical CPUs.
Any ideas?
cpufreq is not being run as asked below
sudo cpufreq-info cpufrequtils 007: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 0: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 1: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 2: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms. analyzing CPU 3: no or unknown cpufreq driver is active on this CPU maximum transition latency: 4294.55 ms.
Braiam
  • 69,112
The Intel Xeon E5-2407 does not have Hyper-threading. Refer to this link. The Intel page you link to also lists the CPU has having only threads across 4 cores.
Bert
  • 3,455
-1
11.10 is really old. Give 12.04 a try at least (if you want LTS... which you probably do.)
It should see all the cores. If it doesn't, report this as a bug.
How do I report a bug?
Apache
  • 5,102
