Is it is possible to forward hardware, which Ubuntu doesnt support?
In my case I want to use a Tascam US-144 audio interface into a VM (which contains Windows) where the hardware can be recognized and used.
Is this possible?
Antigona
  • 248
Chriss
Yes.
You will need to install the closed source extension pack and add your user to the vboxusers group.
I do it quite often to run programs protected by hardware keys that connect to usb machines. Linux doesn't support either the key or the machine (although the machine is probably using a simple usb-serial port emulation). It works nicely with a Windows XP host.
Javier Rivera
  • 35,434
