I get the following error while installing Cinnamon using sudo apt-get install cinnamon:
Reading package lists... Done
Building dependency tree
 cinnamon : Depends: gir1.2-muffin-3.0 but it is not going to be installed
            Depends: libgjs0-libmozjs185-1.0 but it is not installable
            Depends: libgjs0c (>= 1.34.0) but 1.32.0-1ubuntu1 is to be installed
            Depends: libgnome-desktop-3-4 (>= 3.2.0) but it is not installable
            Depends: libmuffin0 (>= 1.1.1) but it is not going to be installed
            Recommends: gnome-themes-standard but it is not going to be installed
            Recommends: gnome-session-fallback but it is not going to be installed
            Recommends: nemo but it is not going to be installed
I tried everything on this:
How do I resolve unmet dependencies after adding a PPA?
but I am still unable to install it. Please help.
By adding the repositories required for cinnamon in this case type this in terminal,
sudo add-apt-repository ppa:merlwiz79/cinnamon-ppa
Then issue the should be fixed if you use 'sudo apt-get -f install (program name)' to get the missing packages. Which should work, But know to add ppa repo's use the above command. Of course replace the repository to the one you want.
edwinksl
  • 24,109
In general, if the dependencies are available on your distro's repository you can do
This will try to install those dependencies but if the required packages are not available in the repository [which is your case] then you will have to manually download and install each dependency starting with the package which doesn't have unmet dependencies. Packages can be downloaded from launchpad.net , packages.ubuntu.com , etc.
This post might help you understand how to resolve dependencies.
I can provide more specific answer if you provide your distro name and version.
sziraqui
  • 645
  • 17
