34
I have Evernote running on Windows. I access the same on my android phone with ease. I want to use the same Windows-run Evernote to use on my Ubuntu, so that the notes fed on Windows Evernote can be used on this.
Could anyone suggest me some solution? My knowledge of Ubuntu is almost nil.
pomsky
  • 70,557
richie
  • 341
10 Answers10
38
You can use Evernote In Ubuntu With Everpad.
Everpad is an Evernote tool that integrates extremely well with Unity. It implements a Unity Lens which automatically searches Evernote notes through the Dash.1
To install, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the commands below:
sudo add-apt-repository ppa:nvbn-rm/ppa
sudo apt-get update && sudo apt-get install everpad
Otherwise, you can install Wine, which allows you to run windows applications.
1Source:Everpad
Mitch
  • 109,787
13
Download the windows version of evernote, install with Wine. It runs beautifully. Fast and with no of the quirks from nevernote, nixnote and so on!
The Linux clone is NixNote https://github.com/robert7/nixnote2
On QT, written in C++
As said by Mitch, you can use Everpad and I personally also use it.
As an alternative, you can also use the Evernote web interface at this address: https://www.evernote.com/Home.action. This will work on all operating systemes.
Agmenor
  • 16,394
You may try Tusk.
Tusk is an unofficial, featureful, open source, community-driven, free Evernote app used by people in more than 130 countries.
Highlights
  • Black, Dark & Sepia Themes
  • Focus, Compact & Auto-Night Modes
  • Local & Global Customizable Keyboard Shortcuts
  • Export Notes as PDF, HTML & Markdown Files
  • Note Navigation
  • Yinxiang Support
  • Cross Platform
  • Scalable Interface
  • Update Notifications
  • Drag and Drop Files
(visit the GitHub page for more info)
Tusk is available as a snap package. So you can install it from the Software (store) application or by running the following command in Terminal
snap install tusk
pomsky
  • 70,557
As of 2021 there is a beta version of an official Evernote client for Linux. You have to sign up for Early Access Program on the Evernote homepage, it is free. You may not (yet) get a link to download the app, though, see comment from Davide.
Earlier it was announced that it is a deb-package. The deb-package can be installed with the Software Center, other tools or via the command line as usual.
I hope there will be soon an official version without the beta-status.
Filbuntu
  • 13,891
CLI solution, written on Python: Geeknote
Evernote is included in the source packages evernote-mode account-plugin-evernote.
Can install with,
sudo apt-get install evernote-mode account-plugin-evernote
You can run Evernote on Ubuntu 14.04, either using PlayOnLinux or Wine directly, everything works fine. Only installing updates is a little tricky which requires removing and installing a new version of evernote.
askb
  • 790
Evernote 5.8.13 working in Kubuntu 16.04 and Wine wine-1.9.18. Version 5.9 and 6.x didn't work.
  1. Install wine: If your system is 64 bit, enable 32 bit architecture (if you haven't already):
    sudo dpkg --add-architecture i386
    Add the repository:
    sudo add-apt-repository ppa:wine/wine-builds
    Update packages:
    sudo apt-get update
    Then install (example for the development branch):
    sudo apt-get install --install-recommends winehq-devel
  2. Download and install Evernote 5.8.13
pomsky
  • 70,557
