14
Ubuntu Detects 2 monitors when I only have 1. This causes an issue when booting up because it's detecting 2 monitors and by default it is mirroring the display; which is causing a distorted picture since it's trying to create a mirror image on 1 display. xrandr output.... The VGA1 is the phantom monitor and I need to remove it so it boots to LVDS1 and NOT mirrored.
Any suggestions on how to permanently remove VGA1?
:~$ xrandr -q
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192
VGA1 connected (normal left inverted right x axis y axis)
1024x768 60.0
800x600 60.3 56.2
848x480 60.0
640x480 59.9
LVDS1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1920x1080 59.6*+
1680x1050 60.0 59.9
1600x1024 60.2
1400x1050 60.0
1280x1024 60.0
1440x900 59.9
1280x960 60.0
1360x768 59.8 60.0
1152x864 60.0
1024x768 60.0
800x600 60.3 56.2
640x480 59.9
Meer Borg
  • 5,003
This seems to be an issue with certain motherboards that have an HDMI and a Display Port. I figured out that either my Gateway ZX6800 Touch-Screen is using a certain Laptop motherboard with the on-board Intel HD chipset that supports this or it is seeing the IR Blaster or TV Tuner and driving it as a monitor.
Either way the fix is: Edit /etc/default/grub add "video=VGA-1:d" between the quotes in the GRUB_CMDLINE_LINUX line update-grub
Look in /sys/class/drm for a list of your computers outputs.Mine was labelled as "card0-VGA-1". Just remove the "card0-" and that's the name of the output in question.
Based on the solution of Matthew Aylard above, I checked the connected cards:
ls /sys/class/drm
The output was like this:
card0  card0-DP-1  card0-HDMI-A-1  card0-LVDS-1  card0-VGA-1  card1  card1-VGA-2  renderD128  renderD129  ttm  version
Then I checked
xrandr -q
Turned out in my case, VGA-1-2 was wrongly detected as my second screen which caused the this issue. So, I edited grub configuration file:
sudo gedit /etc/default/grub
And added two lines to disable both VGA-1 and VGA-2:
GRUB_CMDLINE_LINUX="video=VGA-1:d"
GRUB_CMDLINE_LINUX="video=VGA-2:d"
Finally, updated grub:
sudo update-grub
And after reboot, the second "unknown" display which has been there for years, was gone!
I had similar issue with an integrated Intel HD graphics unit (JUSTOP G-PC iA8 Desktop) and missing mouse pointer.
I thought I would add additional help..
to get the correct video to disable...
ls /sys/class/drm
note the name that is similar to the output from
xrandr -q
e.g. my connected (but non existent extra screen was DSI1 in xrandr but card0-DSI-1 in /sys/class/drm)
based on this information the correct kernal data from /sys/class/drm I was then able to correct the syntax in my...
/etc/default/grub
file to read
GRUB_CMDLINE_LINUX="video=DSI-1:d"
then ran
sudo update-grub
and rebooted, now only one HDMI screen connected and working mouse. Hope this helps other people.
I have what seems to be a similar problem on pop!_OS (based on Ubuntu 19.10),
Adding "video=VGA-1:d" or "video=VGA-1-2:d" (which what seemed to be connected in the xrandr command) didn't solve it.
I used the Fn+(select screen) function in the keyboard to chose the built in only display. And that solved the issue.
Hope this helps someone.
Baha
  • 241
