I noticed this on 12.10 trying to get the Android SDK working. For 64 bit versions, it is required to install:
sudo apt-get install ia32-libs
However, under 64bit 12.10, I got the following error:
 ia32-libs : Depends: ia32-libs-multiarch but it is not installable
And
> apt-get install ia32-libs-multiarch
Reading package lists... Done
Building dependency tree
Package ia32-libs-multiarch is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'ia32-libs-multiarch' has no installation candidate
I found the solution here comment #27,
sudo dpkg --add-architecture i386
sudo apt-get update
Then the 32 bit libraries install fine (for me anyway!). Hope this helps somebody !
pst007x
  • 8,210
The accepted answer no longer works, as you see by comments. I found a working solution elsewhere:
sudo add-apt-repository "deb http://archive.canonical.com/ $(lsb_release -sc) partner"
sudo apt-get update && sudo apt-get install skype
Link is here.
mateor
  • 111
