I'm new to Ubuntu and I'm not a developer to know how to write codes. I downloaded it couple of days ago but it is killing my battery, it almost lasts an hour and couple of minutes while it holds for over than 3 hours with windows.
How to fix this in easy steps to follow?
Do the following things and your battery life will be better
 sudo apt-get install indicator-cpufreq
Place the following script /etc/pm/power.d/ and give execution rights
 sudo gedit /etc/pm/power.d/power
Copy & Paste
 #!/bin/sh
if on_ac_power; then
 ##### Start AC powered settings #####
 # Disable laptop mode
echo 0 > /proc/sys/vm/laptop_mode
 #NMI watchdog should be turned on
for foo in /proc/sys/kernel/nmi_watchdog;
do echo 1 > $foo;
done
 # Set SATA channel: max performance
for foo in /sys/class/scsi_host/host*/link_power_management_policy;
do echo max_performance > $foo;
done
 # CPU Governor: conservative NOT Performance
 # Laptop get start heating up on Performance
 # You can change the freq with indicator-cpufreq
for foo in /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor;
do echo conservative > $foo;
done
 # Disable USB autosuspend
for foo in /sys/bus/usb/devices/*/power/level;
do echo on > $foo;
done
 # Disable PCI autosuspend
for foo in /sys/bus/pci/devices/*/power/control;
do echo on > $foo;
done
 # Disable power saving for intel sound
echo 0 > /sys/module/snd_hda_intel/parameters/power_save
 # Disable power saving for Wireless card
iw dev wlan0 set power_save off
 # Disabling auto suspending USB
for i in /sys/bus/usb/devices/*/power/autosuspend;
do echo 2 > $i;
done
 ##### End AC powered settings #####
 else
 ##### Start battery powered settings #####
 # Enable Laptop-Mode disk writing
echo 5 > /proc/sys/vm/laptop_mode
do echo 0 > $foo;
done
 # Set SATA channel to power saving
do echo min_power > $foo;
done
 # Select conservative CPU Governor
done
 # Activate USB autosuspend
 do echo auto > $foo;
 done
 # Activate PCI autosuspend
done
 # Power Saving for INTEL sound
echo 1 > /sys/module/snd_hda_intel/parameters/power_save
 # Power saving ON for Wireless
iw dev wlan0 set power_save on
 # Auto Suspending USB devices
do echo 1 > $i;
done
 ##### End battery powered settings #####
fi
Make it executable
 sudo chmod +x /etc/pm/power.d/power
Please have a look on the following links
Specific short battery life problem with Sony VAIO laptop
How do I make Powertop changes permanent?
https://wiki.ubuntu.com/Kernel/PowerManagement/PowerSavingTweaks
Qasim
  • 22,162
