13
Recently Intel released their opensource driver tool (https://01.org/linuxgraphics/downloads/2013/intel-linux-graphics-installer) which auto-selects the right drivers for your intel chipset (in my case, I was using the i915 driver). Because I started using Steam on Linux to play some older games I thought I would use the Intel 'official' drivers to ensure I get the best performance. Unfortunately, since installing the drivers, the computer fan is very loud and the battery doesn't last that long (it's cut battery life in half). On top of that, there's no noticeable difference when playing games on Steam.
My question is, how do I revert back to the original drivers?
If I run the Intel graphic driver installer I get the following output in the terminal (not in the GUI) so I assume I will somehow need to run apt-get with some type of downgrade flag (I'm not sure how to do that) against these packages.
install: [i915-3.4-3.2-dkms libdrm-nouveau2]
upgrade: [libcairo2 libcairo-gobject2 libcairo-script-interpreter2 libdrm2 libdrm-intel1 libkms1 libva1 libva-x11-1 libva-glx1 libva-tpi1 libva-egl1 vainfo libxatracker1 libgbm1 libegl1-mesa libegl1-mesa-drivers libopenvg1-mesa libgles1-mesa libgles2-mesa libglapi-mesa libgl1-mesa-glx libgl1-mesa-dri libgl1-mesa-dri-experimental libosmesa6 libglu1-mesa i965-va-driver libva-intel-vaapi-driver xserver-xorg-video-intel libwayland0]
When I look at the install logs though, it seems there's much more than that.
Any assistance on this would be most appreciated.
Braiam
  • 69,112
rimez
  • 822
6 Answers6
10
sudo apt-get autoremove --purge intel-linux-graphics-installer
A solution from http://www.liberiangeek.net/2013/04/how-to-add-intel-linux-graphics-driver-repository-in-ubuntu/
This is what worked for me:
#source http://theclonker.de/?p=89
sudo sh -c 'echo "\nPackage: *\nPin: release a=trusty*\nPin-Priority: 1001\n\nPackage: *\nPin: origin download.01.org\nPin-Priority: -100\n" > /etc/apt/preferences.d/intel-removal'
sudo apt-get dist-upgrade
sudo rm /etc/apt/preferences.d/intel-removal
sudo rm /etc/apt/sources.list.d/intellinuxgraphics.list*
sudo apt-get update
echo "\n\n\n\n\n\n Remember to remove the i915-3.6-3.5-dkms and intel-linux-graphics-installer packages with \n\n sudo apt-get purge i915-3.6-3.5-dkms intel-linux-graphics-installer "
You should change the i915-3.6-3.5-dkms package name to your version.
Source: https://gist.github.com/phdelodder/b28e8df770a6bc020aab
The original source http://theclonker.de/?p=89 was removed.
1ed
  • 141
Here is a possible solution to your problem http://theclonker.de/?p=89
Asraf
  • 31
In the end I found this to be too frustrating to wait for the right answer. In order to fix the situation, I upgraded to version 12.10. It completely wiped all traces of the Intel drivers and I now have a quiet and cooler laptop.
rimez
  • 822
The easiest solution is to use the ppa-purge tool:
sudo ppa-purge -s download.01.org ppa:gfx/ubuntu
This will disable the intel repository and downgrade all packages that were installed from this repository.
leezu
  • 171
In later versions the name has changed; to remove you need to run the following:
sudo apt autoremove --purge intel-graphics-update-tool
Hatem Jaber
  • 326
  • 13
