23
I'm trying to install GStreamer 1.0 on Ubuntu 12.04, the default GStreamer that comes with Ubuntu 12.04 is gst 0.10. I could see that I could download the GStreamer 1.0 source from gstreamer.freedesktop.org, build it and install it. But this installs only the gst plugins only, it does not install the actual required libraries like:
  • mpeg2dec,
  • h264,
  • and other dependent libraries.
These libraries are required by the gst plugins.
ansi
  • 231
5 Answers5
25
If you don't have ubuntu-restricted-extras installed you may need to install that, and any other libraries you require from the repositories.
If you want to install gstreamer 1.0, you need to use the backports for Precise from the gstreamer developers ppa, which is the best source at the minute and the most 'official' developer ppa available.
sudo add-apt-repository ppa:gstreamer-developers/ppa
sudo apt-get update
sudo apt-get install gstreamer1.0*
This will install all the base packages and plugins that you require, and is fine to install, even though you also have the earlier version installed as well, although applications will not use gstreamer1.0 unless they have been built with support for it.
For more information regarding ppas, please see these discussions:
Installing the below package should do the magic
sudo apt-get install ubuntu-restricted-extras
guntbert
  • 13,475
Jegan
  • 61
On Ubuntu 16.04, this worked for me, it might on Ubuntu 12.04 as well:
sudo apt-get install gstreamer1.0-libav
s-heins
  • 281
Install GStreamer on Ubuntu or Debian
apt-get install libgstreamer1.0-0 gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav gstreamer1.0-doc gstreamer1.0-tools
pkgconfig path in my pc:
/usr/lib/x86_64-linux-gnu/pkgconfig/gstreamer-1.0.pc
Building Application using Gstreamer
pkg-config --cflags --libs gstreamer-1.0
kgbook
  • 121
I found that link... and I am adding it. I was trying to install Wine 64bit and I could not figure out how to install gstreamer-1.0 base plugins 64-bit development files
sudo apt-get install libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev**
