this is my story: I left my laptop at home connected to the router and with teamviewer on. Remotely I was controlling it about 2 hours, at a specific moment the connection has disapeared. When I came back, the laptop was on and still connected to the router but no internet connection.
- The router is fine, if I connect another device it works.
- I still can see other wifi networks and try to connect to them.
- I was not installing anything new software on it while controlling it remotely.
- Nobody touched it.
- It was not a power failure, everything was like I left it.
- Tried with a life cd, same situation
- Ubuntu 12.10 on Acer Aspire 7730
ifconfig:
wlan0 Link encap:Ethernet HWaddr 00:16:ea:a4:17:52
inet addr:192.168.1.109 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::216:eaff:fea4:1752/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:15 errors:0 dropped:0 overruns:0 frame:0
TX packets:48 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:4910 (4.9 KB) TX bytes:13172 (13.1 KB)
iwconfig:
wlan0 IEEE 802.11abgn ESSID:"Real+"
Mode:Managed Frequency:2.422 GHz Access Point: 00:18:E7:FA:7F:5F
Bit Rate=58.5 Mb/s Tx-Power=15 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=70/70 Signal level=-36 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:35 Missed beacon:0
route -n:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.1.1 0.0.0.0 UG 0 0 0 wlan0
192.168.1.0 0.0.0.0 255.255.255.0 U 9 0 0 wlan0
ping -c4 173.194.70.113:
PING 173.194.70.113 (173.194.70.113) 56(84) bytes of data.
^C
--- 173.194.70.113 ping statistics ---
4 packets transmitted, 0 received, 100% packet loss, time 3023ms
Interesting the default gateway ping works, ping 192.168.1.1:
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_req=1 ttl=64 time=3.05 ms
64 bytes from 192.168.1.1: icmp_req=2 ttl=64 time=6.23 ms
^C
--- 192.168.1.1 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 3.051/4.644/6.237/1.593 ms
lspci -nn | grep 0280:
07:00.0 Network controller [0280]: Intel Corporation WiFi Link 5100 [8086:4232]
Is this a bad new and I have to buy a new wifi card?
