I have a problem connecting to the internet using Ubuntu 12.04
I'm trying to connect to my home router/ap using my Lenovo T530 . Every other device works just fine on the WiFi. Also, my T530 works just fine on all and any other WiFi except mine. It's not a router issue, I've triple checked.
I attached data for both connections. One shows data from "BlackXs", my WiFi that doesn't work. The other screenshot is done on the same device just seconds later, on another WiFi named "arbo" (my brother's connection up in the attic) working just fine.
Can anyone explain or offer a solution?
Working:
root@t530:/home/augustin# ifconfig wlan0
wlan0     Link encap:Ethernet  HWaddr a4:4e:31:4f:ac:4c
          inet addr:192.168.1.8  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::a64e:31ff:fe4f:ac4c/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:13557 errors:0 dropped:1 overruns:0 frame:0
          TX packets:18810 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:11021816 (11.0 MB)  TX bytes:1781840 (1.7 MB)
root@t530:/home/augustin# iwconfig wlan0
wlan0     IEEE 802.11abgn  ESSID:"arbo"
          Mode:Managed  Frequency:2.462 GHz  Access Point: 7A:D1:5E:12:36:D1
          Bit Rate=1 Mb/s   Tx-Power=15 dBm
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
          Link Quality=28/70  Signal level=-82 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:5  Invalid misc:8   Missed beacon:0
root@t530:/home/augustin# ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_req=1 ttl=64 time=49.5 ms
64 bytes from 192.168.1.1: icmp_req=2 ttl=64 time=1.74 ms
64 bytes from 192.168.1.1: icmp_req=3 ttl=64 time=99.2 ms
^C
Not working:
          inet addr:192.168.0.101  Bcast:192.168.0.255  Mask:255.255.255.0
          RX packets:18396 errors:0 dropped:1 overruns:0 frame:0
          TX packets:24330 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:14264964 (14.2 MB)  TX bytes:3038114 (3.0 MB)
wlan0     IEEE 802.11abgn  ESSID:"BlackXs"
          Mode:Managed  Frequency:2.437 GHz  Access Point: 1C:7E:E5:01:0C:F4
          Bit Rate=65 Mb/s   Tx-Power=15 dBm
          Encryption key:off
          Power Management:on
          Link Quality=70/70  Signal level=-26 dBm
          Tx excessive retries:13  Invalid misc:3   Missed beacon:0
root@t530:/home/augustin# ping 192.168.0.1
PING 192.168.0.1 (192.168.0.1) 56(84) bytes of data.
^C
--- 192.168.0.1 ping statistics ---
3 packets transmitted, 0 received, 100% packet loss, time 2014ms
Solution described here worked perfectly http://www.askubuntu.com/a/279549/261002
