I need to disable my laptop keyboard and use only my usb keyboard, to do this i uses the xinput set-prop command, and since my keyboard id is 16, my command is xinput set-prop 16 "Device Enabled" 0
but when O restart my computer, i need to re-enter the command again, and this is a problem because my internal keyboard has been acting crazy, how do save this changes??
Wilf
  • 30,732
There are different ways of doing this. If you're absolutely sure the ID never changes, the easiest may be to put the line into Systems->Preferences->Startup Applications.
The canonical method seems to be editing udev rules nowadays. There's a Wiki page on this here.
sk29910
  • 2,368
Edit the X.org configuration file located in /etc/X11/xorg.conf . It handles input devices as well as displays
Jorge Castro
  • 73,717
My preferred way of doing this is by appending xinput set-prop 16 "Device Enabled" 0 to ~/.xprofile
