I'm running on a tiny netbook attached to a 22" monitor. When I'm using it without the monitor it makes sense to have the menu bar on the laptop monitor but when I have the big monitor plugged in I want the menu bar on the big monitor. How can I set it up this way?
Asked
Active
Viewed 1,366 times
Set gnome-panel to the first (laptop) monitor type
gconftool-2 --set "/apps/panel/toplevels/top_panel_screen0/monitor" --type integer "0"
For the second (external) monitor use
gconftool-2 --set "/apps/panel/toplevels/top_panel_screen0/monitor" --type integer "1"
If you use awn instead of gnome-panel, this will work too.
bdr529
- 3,098
I use a applet called Jupiter which was originally designed for the eee netbook but should work with any laptop/netbook you can get the deb from their site
or you can add the ppa to get updates - What are ppa's and how do I use them?
open a terminal and type
sudo add-apt-repository ppa:webupd8team/jupiter
then this
sudo apt-get update
and finally this
sudo apt-get install jupiter
one of the functions is to selectively disable either the internal or external displays meaning when you have the big monitor attached you can disable the netbook display having your panels on that screen.
Hope this helps
