I have a Toshiba laptop that was running Windows 8. I installed Ubuntu 12.10 and deleted Windows 8 in the install. Ubuntu worked fine until I shut the PC down. When I tried to start it again it would just go to a black screen. If I take the battery out of the PC and put it back in and turn the PC on Ubuntu will work.
How do I fix this problem?
Seth
  • 59,332
Tim
  • 41
I have a similar problem with one HP Laptop (Pavilion dv6) for more then 2 years look here. What I have discovered so far:
1) Buying another battery doesn't fix the problem,
2) Taking out the battery with the cable connected also doesn't fix it,
3) I have to be careful not to disconnect the power cable when the laptop is shutting down,
4) I have to be super careful not to connect the power cable when the laptop is booting up (but connecting it after the boot seems ok),
5) I got more successful boots with the power cable disconnected,
6) I tried some grub acpi configurations without success.
So I've settled. The two most important steps seems to be the numbers "3" and "4".
Best regards.
desgua
  • 33,215
