31
Previously I was checking the memory usage on my GPU with the following command:
nvidia-settings -q all | grep Memory
I am processing some scientific data on my GPU with numpy and theano. I was doing this with the gnome desktop running, and there was already 380 Mb of memory used on the device. So I stopped lightdm to free up a little more GPU memory; but, now the nvidia-settings tool no longer works.
It simply errors that there is no display
ERROR: Cannot open display ':0.0'.
Is there some other way of getting GPU memory without using this tool? Is there some way to use make it function in headless mode?
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Nathan
  • 873
For Nvidia GPUs:
nvidia-smi
For Intel GPUs:
intel_gpu_tools
For AMD GPUs:
aticonfig --odgc --odgt
For real time watching -- example:
watch nvidia-smi
I think the better way is to install a utility nvtop
E.g. In the following picture almost 100% memory is used on all 3 GPUs and one gpu processor is used 100%. The other two GPU's are used 0%. command is
nvtop
drmaa
  • 363
  • 13
If you want to check memory usage for every 1 second, then the watch command does the job.
watch -n 1 nvidia-smi
Watch feature is actually built-in to nvidia-smi itself
Run
nvidia-smi -l 1
to monitor memory and other metrics at a 1s interval.
