181
How can I display the current time configuration, like the time zone, in Ubuntu?
usef_ksa
  • 1,913
7 Answers7
183
I don't know of a single file, but this may give you the info needed:
cat /etc/timezone
grep UTC /etc/default/rcS
date
# hardware clock
sudo hwclock --show
arrange
  • 15,219
127
Best example (IMHO) using timedatectl (in command-line/terminal):
$ timedatectl
      Local time: Thu 2014-07-24 19:51:23 IST
  Universal time: Thu 2014-07-24 14:21:23 UTC
        Timezone: Asia/Kolkata (IST, +0530)
     NTP enabled: no
NTP synchronized: no
 RTC in local TZ: no
      DST active: n/a
Visit the manpage for more settings and further information.
muru
  • 207,228
Pandya
  • 37,289
35
For me, date works:
Fri 22 Nov 2019 04:31:50 PM UTC
Hunaphu
  • 431
Check out info date, and for example date +'%z'
For the time zone, you can use geolocation:
$ curl https://ipapi.co/timezone
America/Chicago
Or:
$ curl http://ip-api.com/line?fields=timezone
America/Chicago
http://wiki.archlinux.org/index.php/time#Time_zone
Zombo
If you need a formatted area and time zone, you can use:
$ grep `date +%Z` /etc/timezone
  Etc/UTC
If you have PowerShell installed:
PS> Get-TimeZone
DisplayName                : (UTC+02:00) Eastern European Standard Time
StandardName               : Eastern European Standard Time
DaylightName               : Eastern European Summer Time
BaseUtcOffset              : 02:00:00
SupportsDaylightSavingTime : True
I suspect this won't be popular answer in a Linux community, but I really like the verb-noun convention. It makes it easier for me to remember commands, and it will also work on all distributions with PowerShell installed :)
Documentation for the Get-TimeZone cmdlet
Eliah Kagan
  • 119,640
