  1. For pdf: How can I create outlines/bookmarks for and merge them into pdf files in either terminal or in GUI application in Ubuntu?
  2. For djvu: I know how to do the same thing for djvu files in terminal using djvused. I was wondering if there is some gui based application that can create bookmarks/outlines for djvu files more quickly?
Thanks and regards!
belacqua
  • 23,540
Tim
  • 26,107
for the second part of your question I would recommend djvusmooth.
for the first part of your question I would suggest pdfchain should cover your requirements
both are available from the Software Centre.
I personally use a command in terminal to extract text:
pdftotext -layout *.pdf anyname.txt
this will export the text of the pdf to a file meaning you can edit the text in a text editor.
Zanna
  • 72,312
Allan
  • 11,672
