I want to convert djvu to pdf while preserving OCR. This page describes how to do so, but I am getting a blank html file.
In /home/steven/Documents/djvu2pdf/1/, djvu2hocr -p 1 Intro.djvu gives me:
Converting 'Intro.djvu':
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
  <meta name="ocr-system" content="djvu2hocr 0.7.9" />
  <meta name="ocr-capabilities" content="ocr_carea ocr_page ocr_par ocrx_block ocrx_line ocrx_word" />
  <title>DjVu hidden text layer</title>
</head>
<body>
*** [1-11711] Failed to open 'Intro.djvu': No such file or directory.
*** (ByteStream.cpp:693)
*** 'DJVU::GUTF8String DJVU::ByteStream::Stdio::init(const DJVU::GURL&, const char*)'
</body>
</html>
Traceback (most recent call last):
  File "/usr/bin/djvu2hocr", line 7, in <module>
    _.main(sys.argv)
  File "/usr/share/ocrodjvu/lib/cli/djvu2hocr.py", line 325, in main
    djvused.wait()
  File "/usr/share/ocrodjvu/lib/ipc.py", line 114, in wait
    raise CalledProcessError(return_code, self.__command)
subprocess.CalledProcessError: Command 'djvused' returned non-zero exit status 10
leading to a blank html file, so when I run
sed 's/ocrx/ocr/g' > pg1.html
it just runs on an indefinite loop.
I also have a secondary program called djvu2pdf which I found at http://0x2a.at/s/projects/djvu2pdf, but
djvu2pdf Intro.djvu
gives me
-e Error: /usr/bin/djvu2pdf: File 'Intro.djvu' not found
The OCR file opens fine.
I fixed the file /home/steven/Documents/djvu2pdf/1/Intro.djvu. Turns out all my djvu files had no extensions, but linux was opening them anyways.
Testing with a single page document
I first ran cd /home/steven/Documents/djvu2pdf/1/
Then ran: djvu2hocr -p 1 1.djvu
  • Page #1
Traceback (most recent call last): File "/usr/bin/djvu2hocr", line 7, in _.main(sys.argv) File "/usr/share/ocrodjvu/lib/cli/djvu2hocr.py", line 323, in main process_page(page_zone, options) File "/usr/share/ocrodjvu/lib/cli/djvu2hocr.py", line 263, in process_page result = process_zone(None, page_text, last=True, options=options) File "/usr/share/ocrodjvu/lib/cli/djvu2hocr.py", line 238, in process_zone parent.append(child) AttributeError: 'NoneType' object has no attribute 'append'
The command: djvu2hocr -p 1 1.djvu > tmp.html did the same thing Converting '1.djvu': - Page #1 Traceback (most recent call last): File "/usr/bin/djvu2hocr", line 7, in _.main(sys.argv) File "/usr/share/ocrodjvu/lib/cli/djvu2hocr.py", line 323, in main process_page(page_zone, options) File "/usr/share/ocrodjvu/lib/cli/djvu2hocr.py", line 263, in process_page result = process_zone(None, page_text, last=True, options=options) File "/usr/share/ocrodjvu/lib/cli/djvu2hocr.py", line 238, in process_zone parent.append(child) AttributeError: 'NoneType' object has no attribute 'append'
sed 's/ocrx/ocr/g' tmp.html > pg1.html
I got a html & tmp.html saying this
http://pastebin.com/APwUPwk4
Had to post it there b/c for whatever absurdd reason this site won't allow me to post that code, using html, code, pre tags none worked Also what exactly is a pipe, more so where did I miss it in that post? I am new to the terminal in linux, just learning by google searches
First, try running the program with the full path to the file. Run the following command to make absolutely sure that your file exists
and then try
djvu2hocr -p 1 /home/steven/Documents/djvu2pdf/1/Intro.djvu
Second, there is a problem with the following command on itself:
This will not run "in an infinite loop" but will just wait for standard input (keyboard in your case), since you are not running sed with an argument or as a part of a pipe. sed does not know which file you want to process.
The page you refer to clearly specifies that you should run it as a part of a pipe. Alternatively, you can do it as follows:
 djvu2hocr -p 10 /home/steven/Documents/djvu2pdf/1/Intro.djvu > tmp.html
 sed 's/ocrx/ocr/g' tmp.html > pg10.html
January
  • 37,208
