I removed Ubuntu from the efi boot menu but it comes back
i already use easybcd but it still comes back
i try remove it manual from my efi bios but it still comes back
i already delete all of my linux partition(efi / swap)
and i already using efibootmgr via linuxmint
but still it comes back
its even worse because after i use efibootmgr its change my windows efibootloader behavior
i use asus x401u amd c-60
*ubuntu 10.04.01(64bit) already removed but still in my efi bootmenu
*win8pro (64bit)
i already follow this(but via linuxmint) How do I remove "Ubuntu" in the bios boot menu? (UEFI) its still comes back my problem similar like this ubuntu appears in BIOS menu (UEFI) and im gonna do this I removed Ubuntu from the BIOS menu but it comes back later
please help me
Try mounting your EFI System Partition (ESP) and removing the EFI/ubuntu directory from that partition. Then boot a Linux emergency system in EFI mode and use efibootmgr to remove the Ubuntu entry. For instance:
# efibootmgr
Timeout: 10 seconds
BootOrder: 0000,0008,0006,0007
Boot0000* ubuntu
Boot0006* Hard Drive
Boot0007* CD/DVD Drive
Boot0008* INTERNAL EFI SHELL: ST32000542AS
# efibootmgr -b 0 -B
You'll need to modify the value passed to -b based on the initial efibootmgr output.
Rod Smith
  • 45,120
  • 66
  • 108
