For reasons too long to explain, I reluctantly removed Ubuntu from my computer. After completely removing it and deleting the partition that it was installed onto, I discovered that I still had two Ubuntu entries in the boot order in my BIOS menu. I deleted them by following the instructions in this answer:
https://askubuntu.com/a/63613/54934
As I was doing it, everything appeared to go smoothly. However, upon reboot one of them came back. What's going on here? How do I delete it permanently?
Here is my boot-info URL: http://paste.ubuntu.com/1372806/
I'll gladly provide any other information that may be needed to diagnose the problem.
Thanks.
jimchristie
  • 4,987
  1. Boot on a Ubuntu 64-bit disk, choose Try Ubuntu.
  2. Open a terminal and type the following commands:
    sudo mount /dev/sda2 /mnt
    sudo rm -r /mnt/EFI/ubuntu
    sudo efibootmgr
    This should display your boot entries, each with a number. E. g., if your Ubuntu(/Shim) entries are number 0002 and 0003, you can remove them by typing:
    sudo efibootmgr -b 2 -B
    sudo efibootmgr -b 3 -B
David Foerster
  • 36,890
  • 56
  • 97
  • 151
LovinBuntu
  • 3,785
i finally managed to get rid of my useless "fedora" boot option by deleting the "fedora" folder inside the EFI partition. I used EasyUEFI's EFI browser feautre on Windows.
https://www.easyuefi.com/faq/en-US/explore-and-write-efi-system-partition-explorer.html
Levent
What sort of motherboard do you have? (Brand and model, firmware brand?) I've got an ASUS P8H77-I motherboard that has a similar problem -- after I installed Ubuntu, I got two entries in its firmware list, and any attempt to delete either of them resulted in it reappearing after a reboot. I finally cleared the problem by removing all of the firmware's boot entries and then re-creating only the ones that I wanted. It could be that a similar procedure would work for you.
Rod Smith
  • 45,120
  • 66
  • 108
