I dual-boot Windows 7 and Ubuntu 12.04.
I want to be able to virtually boot this windows installation inside Ubuntu.
While trying to do this using qemu qemu -hda /dev/sda -m 2048 I am able to see the GRUB loader, I select Windows and then I just get the Blue screen of death.
So, how do I boot the existing installation of windows as a Virtual Guest in Ubuntu.
The solution need not be only qemu related. It can be any virtualization solution.
Note:
I don't want to convert the existing installation into a virtual disk and then use it. I want to be able to directly boot the existing windows installation.
Basically all changes made to Windows from inside Ubuntu should reflect in the native Windows installation.
Hashken
  • 6,340
http://lifehacker.com/how-to-dual-boot-and-virtualize-the-same-partition-on-y-493223329
Try the above link.It will give you a hint.
