I installed otrs like so:
sudo apt-get install otrs
And in the end it gave me this error below.
Setting otrs2 (3.1.7 + dfsg1-5) ...
dbconfig-common: writing config to / etc/dbconfig-common/otrs2.conf
Replacing config file / etc / OTRS / database.pm with new version
Already perl module enabled
Already rewrite module enabled
  * Reloading web server config apache2: Could not reliably determining the server's fully qualified domain name, using 127.0.1.1 for ServerName
        [OK]
DBI connect ('database = OTRS, host = localhost, port = 3306;', 'OTRS', ...) failed: Access denied for user'' @ 'localhost' to database 'OTRS' at / usr / share / OTRS / Kernel / System / DB.pm line 256
ERROR: OTRS-otrs.RebuildConfig.pl-10 Perl: 5.14.2 OS: linux Time: Wed March 13 2013 12:01:17
  Message: Access denied for user'' @ 'localhost' to database 'OTRS'
  Traceback (7612):
    Module: Kernel :: System :: DB :: new (v1.144.2.1) Line: 227
    Module:. / Bin / otrs.RebuildConfig.pl (v1.14) Line: 55
Got no DBObject! at / usr / share / OTRS / Kernel / System / SysConfig.pm line 103.
dpkg: error processing otrs2 (- configure):
  subprocess installed post-installation script returned error exit status 255 back
  otrs2
E: Sub-process / usr / bin / dpkg returned an error code (1)
I have a dutch Ubuntu the error above I copy/paste it in Google translater
blade19899
  • 26,994
This is a problem with the Ubuntu package. While the OTRS debian package is pretty well maintained, the Ubuntu package (which is derived from the Debian package) is broken and no-one really seems to care about it. See all bug reports here:
https://bugs.launchpad.net/ubuntu/+source/otrs2
So if you want to install OTRS from a package manager, choose Debian, or if you want to install OTRS on Ubuntu, please look at this procedure:
http://wiki.otterhub.org/index.php?title=Installation_on_Ubuntu_Lucid_Lynx_(10.4)
(yeah I know it is written for Ubuntu 10.04 and OTRS 3.0.x but the procedure is really very much the same)
MichielB
  • 334
