I installed Kubuntu 12.04 on this desktop last September and am the main user of the machine. I can perform most admin tasks such as installing new software with my password, which is also accepted using sudo in a terminal. Some tasks however ask for a root password - the most recent example being when I tried to re-install my HP printer. and my usual password does not work. I have looked at this answer, but it doesn't seem to help as I know my own password. I need to know root's password!
WGCman
  • 347
Running sudo -i in the console will drop you into "root" mode.
Panther
  • 104,528
Tron
  • 568
Ubuntu by default does not have a root password set and relies on your own password entered via sudo for superuser/sysadmin purposes.
If you are adamant on setting a password for root then the following command will do it but it is NOT needed.
sudo passwd root
I would suggest just using sudo and then enter your own password.
haziz
  • 3,067
