I can't install Ubuntu (12.10 and 12.04) (also tried Mint) on Z585 (Lenovo IdeaPad Z585 AMD A8-4500M 1.90GHz 8GB 1TB DVDRW DL FreeDOS 15.6" HD AMD Radeon HD7670 2GB).
I tested all possible options and still no luck so this is my call for the help.. Hope that someone knows something that is not yet listed:)
EDIT the steps I made:
  1. disable UEFI (also tried with enabled)
  2. Attempt to install Ubuntu from DVD
  3. Select "Install Ubuntu"
  4. Change options: acpi=off; nomodeset (tried all combinations)
  5. Press enter.
Result: Shown a black screen with blinking cursor- no errors no nothing, I can't enter anything and I can only turn off the laptop via shut button (by holding it) so I never got trough installation (Same thing I get if I do "Try" instead of "install").
Note that I had no trouble installing Windows 7.
p.s. I also tried the following:
My computer boots to a black screen, what options do I have to fix it?
Booting Ubuntu with "acpi=off" grub parameter
http://ubuntuforums.org/showthread.php?t=2077126&page=3
How do I set 'nomodeset' after I've already installed Ubuntu?
BTW I get stuck every time on black screen with blinking cursor only.
Thanks
sinek
  • 91
5 Answers5
I would give a try booting from USB, the advantage is that you can check the iso-image afterwards with md5sum. Sometimes simple read/write errors can cause unusual beheaviour of a self-burned image-cd.
  • Did you check the DVD for errors ?
  • Did you try with a CD, a DVD and a USB flash drive ?
  • Did you try updating your BIOS to the latest version ?
  • Did you try removing every unnecessary device like external mouse, external keyboard, webcams or even disabling your USB ports and network cards in the BIOS ? (I can do this on my ThinkPad, I don't know if this is available on an IdeaPad)
  • Did you try using an older version and upgrading ?
  • Did you try with 32 and 64 bits versions ?
Good luck!
phil
  • 55
Try this:
  1. Quick possible solution: What you describe looks like a Graphic card problem. Try to disable the card by running notebook with powersave option, not the performance option. Performace forces 3D card running all the time and can cause a problem.
  2. If this does not help, download fresh ISO, get PendriveLinux http://www.pendrivelinux.com/yumi-multiboot-usb-creator/ and try Live without install, to confirm that it is working in general and it is not caused by installation process.
I have xubuntu on Z560/Nvidia with almost no problem, but the support of the G. card can sometimes fail on specific kernel-driver configurations.
Dee
  • 1,986
I managed to install 12.10 on a Z585.
In the preinstalled Windows 8, hold Shift when clicking on "Shutdown", then click yourself through the menu to make it boot into the UEFI options (you have managed that already so just do it again).
There, disable all options regarind Windows, e.g.:
Optimized for [Other OS]
etc., until it says:
Secure Boot [Off]
After that, I was able to install Ubuntu without problems.
Sorry for the vague description, I don't recall the individual steps any longer and can not find the website I used for instructions.
BuZZ-dEE
  • 14,533
-1
I successfully installed openSUSE in UEFI mode on my IdeadPad Z585, in dual boot with Windows 10. I know it's possible now to do the same with Debian and Ubuntu.The only way I managed to make it work in legacy mode in the past was by using a 32-bit version, which wasn't ideal. Here's a good video that explains how to do it step by step. I hope it helps. https://www.youtube.com/watch?v=WulgG1GeJ4U It shows how to do it on Elementary OS, but since it's based on Ubuntu, it should work. Have fun!
