21
I have a dual boot on my computer of Windows 7 and Xubuntu 12.10. The Linux boot is 1st and the Windows 2nd. I would like to reverse the boot order in the GRUB menu. I need to know the steps to go about editing GRUB. I do most of my work on Windows and need it to be 1st so I can boot up and not watch it.
Zanna
  • 72,312
I dont know if you can change the order of the menu in an easy way, but you can set the default entry.
In terminal
sudo -H gedit /etc/default/grub
I don't know what your grub menu looks like but let's say you have:
  • Ubuntu
  • Memory test
  • Windows 7
in this case, if you want Windows 7 to boot by default you replace GRUB_DEFAULT=0 with GRUB_DEFAULT=2
Save the file and in terminal:
sudo update-grub
and reboot
Zanna
  • 72,312
Kempe
  • 2,805
11
The menu entry of "Windows 7" in /boot/grub/grub.cfg may look like this:
menuentry "Windows 7 (/dev/sda1)" { #it's depend on your config
You can also write GRUB_DEFAULT="Windows 7 (/dev/sda1)" to /etc/default/grub to avoid the order problem in grub.cfg.
BuZZ-dEE
  • 14,533
Oling Cat
  • 111
